Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 01-04-2004, 01:55 PM
Pappy is on a distinguished road
Need help with toolpath control
I have read several posts on how the lines are drawn randomly in some cad programs and the resultant conversion to toolpaths is also somewhat random. Is there any way to edit a cad file to provide a more logical path for toolpath generation without re-drawing?
Old 01-04-2004, 02:03 PM
balsaman's Avatar
balsaman is on a distinguished road
You could copy and paste them to a new layer in the order you want them cut.
Ace converter does an OK job of optimizing the cut order...
Eric
I wish it wouldn't crash.
Old 01-04-2004, 02:24 PM
John S. is on a distinguished road
Why?
Any decent CAM program will take a profile or path and generate the nessesary code regardless of how it's been drawn.
Let's face it if you select a closed shape and a start point, then select the side you want to go in even if it was drawn haphazardly there is only one path to take.
It's not rocket science.
Cam programs that still rely on the way the drawing was made are a throwback to the dark ages.
John S.
Old 01-04-2004, 02:34 PM
balsaman's Avatar
Well,
We are not all made of money, some some of us still use the cheap/freeware cam packages.
Eric
Old 01-23-2004, 05:29 PM
Gold Member
RickOmatic is on a distinguished road
Like Eric said, we are not all made of money is a valid point, but there are other considerations as well. I use Quick cad (Autodesk) because it is a fast and uncomplicated program. The majority of my work is 2d, so a larger, more complex cad program is not nessisary. One of my computers (300mhz ibm) runs my old , old programs quickly and nicely. K-cam v3.28 does well, later versions will not run as well. Corel draw 3.0 for eps to dxf, no problems! I do spend a good bit of time either cutting and pasting in order of cutting, or do a quick fix in g-codes. If I could figure out how to change the order (called an uid#, unique identification number) that would be great. As of now, nobody has been able to help. Any thoughts out there? Thanks! Rick
G-Code to DXF WayneHill OpenSource Software 200 04-22-2012 09:51 PM
Stepper control software suggestions jlawren6 General CAM Discussion 6 05-21-2011 05:42 AM
Visual Basic Controller Project dwwright Visual Basic 29 02-14-2011 01:24 PM
CNC Glossary CNCadmin CNCzone Club House 17 03-09-2008 03:08 PM
HAAS Indexer Prodramming / Control CAMmando Haas Mills 8 06-10-2003 10:22 AM
