Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 09-12-2006, 10:28 AM
BMackinnon is on a distinguished road
german transaltion question
Im not sure if this is the right sub-fourm or not (feel free to move it else wise)
I have a german drawing here that I am doing over in english for a customer and I am having problems with one note. I used a translator program for the words but it still got me nowhere.
"ACHTUNG: Anschweissbolzen
pos. 5 und 6 noch
zusaetzich mit
a=3 verschweissen"
from the program I used i got the following translations:
ACHTUNG = Attention/ Warning
Anschweissbolzen = white bolt
pos. 5 und 6 noch = pos. 5 and 6 yet
zusaetzich mit = in addition with
a=3 verschweissen = ??? weld
Im just wondering if someone on here could make any sense of this for me.
thanks in advance
Old 09-12-2006, 11:31 AM
Switcher's Avatar
Moderator
Switcher is on a distinguished road
Anschweissbolzen = welded bolt
I think
Maybe this will help.
Link:
http://englisch.germanien.name/da11.htm
Old 09-12-2006, 11:55 AM
fkaCarel is on a distinguished road
pos. 5 und 6 noch
zusaetzich mit
a=3 verschweissen"
Attention: Weld-on bolts position 5 and 6 also weld with a=3.
Old 09-12-2006, 01:08 PM
Gerald_D is on a distinguished road
Bolzen could be a bolt, shaft, or pin....
Try a Google Image search on the words.
weiss=white
schweiss=weld
Old 09-12-2006, 02:50 PM
yes thank you all for the info ... thats about what I can come up with and right now im reading an article on a=3 and i believe this will explain it all .
thanks again fellas
Old 09-12-2006, 03:03 PM
I think the a=3 is the specified thickness of the 45 degree weld around the bolt. The bolts are stump-welded or welded from the rear.
Old 09-12-2006, 03:21 PM
mxtras's Avatar
Silver Member
mxtras is on a distinguished road
A=3 denotes the size of the fillet.
Scott
Consistency is a good thing....unless you're consistently an idiot.
Old 09-12-2006, 03:33 PM
Sorry, language problem, I can't get fillet into metal. In my dictionary it is: A) piece of boneless meat from near the loins or ribs. B) A strip of ribbon etc. worn round the head.
So what is the metal fillet?
Old 09-12-2006, 03:47 PM
Radius joining two planes; chamfer with a radius.
Old 09-12-2006, 03:53 PM
mxtras's Avatar
Silver Member
Or Leisteschweißung perhaps - 'border' weld.
Scott
  #11   Ban this user!
Old 09-12-2006, 03:56 PM
So a weld with a radius. Never drawn it, never seen it on a drawing. But we're only speculating over a drawing we don't see.
  #12   Ban this user!
Old 09-12-2006, 04:07 PM
I misled you slightly because I did not notice you were referring to a weld. The bead of metal you lay down when welding is also a fillet.
I tried various different terms in the Altavista Babelfish translating from English to German and back and got things such as 'legs around corners'. Machine translation is not reliable.
