Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 12-21-2003, 09:40 AM
Jan Jan is offline
Jan is on a distinguished road
CAM Expert
Has anyone used CAM expert?
here's a link for more info:
http://www.ribbonsoft.com/camexpert.html
Would some kind soul take a look and see if this will work for outputing the correct g-code and control the router.
There's not a lot of info on google relating to users or operation of this software.
I did email the maintainer and he responded:
(question)> Any further info or developements, such as can this proggy be used to control a cnc homemade router?
response:
Most likely yes - you can adjust the output format individually.
Free trial versions (60 days) are available from:
http://www.ribbonsoft.com/camexpert_downloads.html
If you can send me a sample output file, I can tell you more
about adjusting the format.
end quote
thanks for the help
jerry
Old 12-21-2003, 10:45 AM
HuFlungDung's Avatar
Moderator
Hi Jan,
I took a look at it. I think you'd be better off with Bobcad, even version 17, which is quite inexpensive.
Tool up, and tool down is important stuff, and I don't see it being really handy in Camexpert.
Also, I did not notice an offset function in Camexpert, which you would need to be able to offset from your wireframe part, by the amount of your tool radius.
I like the accel/decel feature of Camexpert, that is nifty for an inexpensive program, but is really only required for high feedrate machines.
Old 12-21-2003, 01:10 PM
Jan Jan is offline
would this be a good g-code generator?
Old 12-21-2003, 01:35 PM
Moderator
Considering it has no Z axis, its pretty limited. Try it out and see if it suits your needs. Check the way that it outputs arc information first, to see if the output can be configured to match your controller requirements.
Then, work out the start line, toolchange, and end lines sequences.
Then, like I said, check out how you create offset toolpaths with it, to make sure it can handle it.
The author himself says the package is not a milling software, so, depending on how you wish to use your router, this will determine if you are emulating a 2d profiler (like lasar or plasma) or a 3 axis mill.
Old 12-21-2003, 02:54 PM
Jan Jan is offline
ok, thanks for the info,I don't have any router setup to check out useage at this time, but was doing some reasearch
again thanks
jerry
Student Versions of CAD and CAM Software Jcadwell General CAM Discussion 8 08-04-2008 09:22 AM
Any ideas for open source CAM package? galacticroot OpenSource Software 26 10-22-2007 11:35 AM
CAD CAM Demo strategy questions? Idle hands General CAM Discussion 6 05-24-2005 01:45 PM
Newbie CAM questions WoodSnarfer General CAM Discussion 3 11-12-2004 07:15 AM
Cam design??? anoel G-Code Programing 8 01-09-2004 08:06 AM
