Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 08-22-2006, 11:04 AM
Karl_T's Avatar
Karl_T is on a distinguished road
machine a stencil
I need to machine a simple stencil in AL plate. Then use it to spray paint a label on a number of items.
I have access to Autocad 2005 and Mastercam X.
So far, I downloaded a stencil font and installed it for use in programs like Word. I can't figure how to use this font in Autocad.
Any ideas? Other routes?
Karl
Old 08-22-2006, 11:07 AM
*Registered*
lakeside is on a distinguished road
you should be able to do the font in mastercam x. Look in your help files under text and vectorize text. I'm not a mastercam person so this is a guess about help files
Old 08-22-2006, 12:24 PM
Karl_T's Avatar
KEWL!
Quick and easy. I'm too used to drawing in autocad and transferring. Should have just looked at doing it direct.
Karl
Rekd's Avatar
Rekd is on a distinguished road
Not sure about X, but I know you can't machine fonts (as in created via drafting or something similar) in previous versions of MC without converting it. (Lakeside might be on to something with vectorizing, look into that first.)
In v9, you could use Create/Next Menu/Letters and select the font you want. If the font isn't available, you will need to install it to the system (OS) first, then select it from the True Type button, instead of doing it in Autocad.
HTH.
:edit: looks like you figured it out, and I type slow.
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
