Results 1 to 7 of 7
Thread: files convertion
    fjd
    fjd is offline
    Registered fjd's Avatar
    Jul 2003
    files convertion
    is there a good way to convert 15yrs worth of smartcam files
    to gibbscam
    Mar 2003
    Eastern CT
    My guess is only the solids and surfaces, not processes.
    At least ya don't have to model 'em all again.
    "The source of expertise is not in the memorization of the minute details of a subject but in the thorough understanding of the fundamental concepts on which it is based." --author unknown
    Community Director cadcam's Avatar
    Apr 2003
    How about a converter that would take the smartcam file and change them into Iges? Of course you would loose the tool paths that is for sure.
    But I have a converter for the first part of my statment.
    Cadcam
    Owner, contract Programming and Consultant , Mastercam Instructor and on line trainer at www.eapprentice.net
    Some tips: http://www.youtube.com/PrecisionProgramming
    Registered cadman's Avatar
    Jun 2003
    Can't you export your part files as igs, parasolid...? I'm not familiar with Smartcam but I assume all cam systems can at least export part files as an igs format.
    fjd
    fjd is offline
    Jul 2003
    I am not familar with samartcam eather the company
    that i work for is using it and thinking of changing to gibbs
    and u can here all kinds of promises from salesmen.
    thats why i ask here also.
    thanks
    FORD = First On Race DAy
    Jun 2003
    Open up Smartcam and see what kind of files you can save as or export to. Igs is the most common format that is used by nearly all cad & cad/cam software for the past decade or so.
    Part files with no surfaces (geometry only) will need to be exported/saved as a dxf file.
    If you want to be sure it will export into Gibbs you can email a file to me and I'll open it up and send back a screen shot to you so you can see what it looks like. I'm a Gibbs user.
    Whatever system your company eventually gets you will probably need a couple coffee breaks to get all those files exported and imported. If time is a consideration you may want to try a cad service that can convert all those files for you.
    Apr 2003
    Or later when I can get a moment I will move over the converter to the FTP,the one I was stating earler that will do a hole dir.
    of smartcam files for you.
    And if the files are 2d and do not contain surfaces you can still use iges if you want.
    Cadcam
    1. How to view iges files
      By Hack in forum TurboCAD/CAM
      Last Post: 05-07-2011, 04:03 AM
    2. CAD Files for Machine Design
      By Hack in forum DIY CNC Router Table Machines
      Last Post: 12-12-2004, 03:58 PM
    3. solid works cnc files
      By krustykrab in forum Mastercam
      Last Post: 06-19-2004, 10:53 AM
    4. Convert to G-code files
      By quickerz in forum Solidworks
      Last Post: 05-30-2004, 12:55 PM
    5. .bin Files
      By sundara in forum General CAM Discussion
      Last Post: 09-13-2003, 06:33 PM
