Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 06-18-2006, 02:31 AM
dbtoutfit is on a distinguished road
OMG all the toolpaths!!!
Ok I am going out of my mind.
I need to cut some pc's for a RC plan kit.
I have them CAD in DXF and the run them in Mach 2 to convert to gcode.
Oh and between DXF and Mach 2 I converted to plotter in Corel.
When I convert the DXF to gcode I get like 50 or more tooth paths.
I ran the Sim and got 18 mins to cut a pcs that would take maybe 3 mins with a jig saw.
There are just to many tool paths. The pc is egg shaped with the center cut out. But the tool path runs a 1 inch cut then picks up goes to the top of the pc does the same then runs some where else all star shapped. I need it to drop once run the full inner circle, pick up and drop and route the out circle.
I need help
BTW I used corel draw to group the layers cause I thought the tooth path was picking up each line from each layer, I soon found out it did me no good.
Theres a good side to every bad side, you just have to look around the corner.
Old 06-18-2006, 06:09 AM
ger21's Avatar
Try drawing the inside and outside each as 1 continuous line. The star shapes are probably the rapid moves.
Old 06-18-2006, 11:33 AM
If by rapid moves you mean when the z is moving to location without cutting, then yes thats the prob. The code has way to many rapid moves all in red in mach 2 in star shape.
Well I am not cading the parts so I would have no idea as how to make them continuous. All I know is corel and I have just started using it.
Is there some kind of program that I can load the gcode into and it will show the tool paths with all the rapid moves and I can edit the rapid moves?
Old 06-18-2006, 12:24 PM
turmite is on a distinguished road
Post your file here and I will backplot it, re-do the toolpath and let you try that.
Mike
No greater love can a man have than this, that he give his life for a friend.
MetLHead's Avatar
Gold Member
MetLHead is on a distinguished road
If you can post the DXF file that you have, I'll see if I can convert it to a more optimized G-Code.
Scott
Old 06-18-2006, 12:32 PM
Thanks guys.
I did work with it a bit and I got the rapid moves knocked out a lot. My prob now is its cuts the same lines one way then goes and cuts it again another way. lol
I am not sure how to post files?
I will try.
Ok i think I got it but it would only allow me to up the dxf file.
I have a lot of patterns like this to do so I am looking for help on how to do this myself mostly as I am sure no one wants to do all these for me
Old 06-18-2006, 12:42 PM
MetLHead's Avatar
Gold Member
OK, here's what I came up with. I had to load it into Rhino and convert it to an R12 DXF file so that I could bring it into NCPlot. But once in NCPlot, it's pretty simple to join the objects into a joined chain and convert to G-Code.
Regards,
Scott
File Type: txt Drawing2.txt‎ (798 Bytes, 57 views)
