Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 05-17-2006, 01:57 PM
GAWnCA's Avatar
GAWnCA is on a distinguished road
From The Ground Up
Greetings, I'm new to all of this and was wondering, What is the software requirements starting from zero for cutting 3D objects on 3, 4 or 5 axis? What are the favorite, least expensive, programs staring from design to actually turning on the machine and making the cuts? I know you need to use a CAD program or something that will alow you to design, something then to convert to a DXF file if you are using a .bmp, .jpg, etc. but where do you go fomr there?
Thanks.
Old 05-17-2006, 07:09 PM
ger21's Avatar
The CAD program should export .dxf's, or .stl files to load into a CAM program. You might want to take a look at MeshCAM, www.meshcam.com
Old 05-17-2006, 07:18 PM
motomitch1 is on a distinguished road
Onecnc XR2 http://www.onecnc.net/index.htm
Old 05-17-2006, 09:28 PM
GAWnCA's Avatar
Thanks to both of you for these 2 resources. Now I have to play with each one to see which will be easier for me to learn. HA HA, I'm getting older and things don't come as fast as they use to.
Old 05-17-2006, 09:41 PM
GAWnCA's Avatar
Here's another question. Do both of these allow you to connect and controll through your own controller board? or do I now have to have another software package to do that?
Old 05-17-2006, 10:15 PM
ger21's Avatar
These just create g-code. You'll need a machine control program. try www.artofcnc.ca
Old 05-17-2006, 10:42 PM
GAWnCA's Avatar
ger21,
Thanks. I see that MeshCAM can be bought with Cutviewer and Mach 3 for $425. Think that's a good deal? I'm using TurboCAD v12 and I have AutoCAD 2000. Haven't learned either one but I can buy books for AutoCAD and they are hard to come by for TurboCAD. That should set me up pretty good with all these packages, correct?
Old 05-17-2006, 10:44 PM
GAWnCA's Avatar
Motomitch1, Can you give a ball park cost of IneCNC XR2? I hate getting on mailing lists. Thanks again for your input.
Old 05-17-2006, 11:11 PM
ger21's Avatar
OneCNC = ~$1500-$5000, depending on options.
Old 05-17-2006, 11:14 PM
ger21's Avatar
Cutviewer is $400 if purchased seperately, so I'd say yes, it's a good deal. Unless you don't need Cutviewer.
  #11   Ban this user!
Old 05-17-2006, 11:18 PM
GAWnCA's Avatar
WHEW!!! Sort of takes it out of the hobbyists hands unless you did very good on your stocks. HA HA
  #12   Ban this user!
Old 05-17-2006, 11:24 PM
GAWnCA's Avatar
Not sure what Cutviewer is but as long as it is in the bundle, why not.
