Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 05-16-2006, 05:33 PM
Burn is on a distinguished road
Looking for semi-cheap CAD software
Hey Guys,
I'm going through with my mini-mill conversion, and I need CNC software. I've tried CAD X11, with little success. Can anyone reccomend me some relatively inexpensive CAD software that supports 3D?
Thanks guys,
Burn
Old 05-16-2006, 05:40 PM
pstockley is on a distinguished road
Try alibre express (http://www.alibre.com/ ) its free! Not quite as good as solidworks but not far off.
Old 05-16-2006, 05:47 PM
*Registered*
lakeside is on a distinguished road
if your looking for cad/cam Bobcad version 20 can be had for $500 and some crying to salesman it might go for $300
Old 05-16-2006, 05:53 PM
Heh...I'll give alibre express a go and let you know. Is there a steep learning curve?
Old 05-16-2006, 06:06 PM
ynneb's Avatar
Moderator
ynneb is on a distinguished road
http://www.freebyte.com/cad/cad.htm
Old 05-16-2006, 06:17 PM
There is a learning curve for parametric modellers in general. Alibre has decent tutorials and online videos. Don't try to use it without going through them. I was new to 3D modellers about 4 months ago. Now I don't know how I managed without one. Especially if you are designing mechanical type assemblies it is really nice to try different designs and change dimensions on the fly. I have to admit I use Solidworks and don't use alibre but I have played with the free version and they are very similar to each other.
Old 05-17-2006, 08:51 PM
Got another question- When I have my DXF file, how can I convert it into G-code?
Old 05-17-2006, 09:42 PM
ynneb's Avatar
Moderator
This is where you now need CAM software to do the conversion.
There is lots of options, but 3D CAM is much more expensive than 2.5 D CAM software.
From my reading MeshCam is the cheapest 3D Cam software availiable. http://www.grzsoftware.com/
Old 05-17-2006, 10:12 PM
ger21's Avatar
For most parts that you'll model in Alibre, a 2.5D CAM program will probably be a better option. Check out www.sheetcam.com
Old 05-17-2006, 10:28 PM
Thanks guys
Hm...Both are $150...Which one should I go for?
  #11   Ban this user!
Old 05-17-2006, 10:42 PM
Hmm...In Mach3, it lets me generate a G-Code .tap file by clicking on import DXF from the file menu.
Old 05-17-2006, 11:09 PM
ger21's Avatar
Both have demos. Try them and see which one works best for the type of work you plan on doing. Les will give you a 30 day code for SheetCAm if you ask him.(email)
Yes, Mach3 will create g-code from .dxf files. SheetCAM will give you much more control over the process. Also try out Mach3's new .dxf converter, LazyCAM. Free with Mach3.
