Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 05-12-2006, 01:29 AM
Sanghera is on a distinguished road
How to convert text to dxf for Sheetcam
I was wondering what the best program, or a good program, cheap, is to convert text into dxf so that Sheetcam can take it in. Autocad can do this, but if you use any other font, it doesn't work, and Autocad's formatting, sizing isn't the best for this. Just wondering what you use and what is good to use for this. Something that is cheap or free for the Hobbyist.
Thank you.
Old 05-12-2006, 02:30 AM
I have found a program called OulineArt from dwg.com, are there any other free one's. By the way this program runs great. Is there any better way to do with Autocad?
Thanks.
Sanghera.
Old 05-12-2006, 07:20 AM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
It has been MANY years since I have used ACad.
I believe you can explode the text to turn it into line segments.
It won't take long to try anyway.
www.integratedmechanical.ca
Old 05-12-2006, 09:08 AM
ger21's Avatar
Not unless you have the Express tools, or a newer version of AutoCAD that includes them. And even if you do, they'll require cleanup. I've found Outline Art to be much faster, although it's conversion is slightly different than ACAD's.
