Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 05-04-2006, 03:44 AM
petr_blazek is on a distinguished road
Unhappy Programming of constant acceleration
I am student of Czech Technical University. I would like to know, how make a program for tool which moves in line(for example 500 mm) with a constant acceleration.
thanks
Old 05-04-2006, 05:03 AM
fkaCarel is on a distinguished road
embedded or non-embedded?
Old 05-04-2006, 05:22 AM
embedded
Old 05-04-2006, 05:27 AM
double timer. 1 variable for step-step timeslice, 1 constant timeslice for determining moment for adjusting step-step timeslice.
Old 05-04-2006, 07:05 AM
I would like to know,how write it to ISO NC code.
thanks
Old 05-04-2006, 07:34 AM
That's not at the embedded level. You want constant acceleration, with NC code you can approach constant acceleration. It is the settings and the internal programming of the controller you command, which control the way it is executed. That's as far as you can go, from an embedded level view.
Old 05-04-2006, 07:57 AM
FarmerDK is on a distinguished road
I might be saying exactly the same thing as Carel, I'm not a english-shark. I would write a macro that would increase the speed, lets say every 1mm. Thats a principle, but how to write the code will differ from machine to machine - they all have different capabilities and syntax'es.
Did that help at all ? :-D
