| General CAM Discussion Discuss CAD/CAM software and Design software methods here! |
Hi guys whats the most user freindly cad cam software available to date .And whats the best software for just running g-code Dos or Windows? Ive heard alot of good things about the Dos programs and also that they dont do constant cotouring very well and I've heard that some of the Windows programs don't work well because windows inerferes with the code thru the use of some sort of timers in the OS software .Is there a reliable software out there to run code that wont cost a fortune? Also I need to run 4 axis and need to do constant contouring I don't want any herky jerky movement. What would be the minimum controller software setup thats needed to do this?Do you need small step angles like .9 or smaller or can it be done with 1.8? thanks guys for your help. Bob |
| check out the review of Mach2 controller software posted elsewhere in this wonderful site. I've only tested demos of many controller softwares. Have Mach2 and so far it does smoothly what it is designed to do.
__________________ Shoptask rebuild: http://www.cnczone.com/forums/showthread.php?t=2139 Home built gantry router: http://www.cnczone.com/forums/showthread.php?t=5049 |
Are you going to use this on a home unit or a real shop envirement?
__________________ (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) Cadcam Mastercam Instructor , Programming Consultant and ME (Manufacturing Eng) |
I'd be using this at home on a 3x5 machine for sign making.I wouldn't be opposed to spending upwards of a thousand dollars if the software was trully user friendly and reliable,easy to configure and setup on my machine....Bob |
| What type of shaps will you be cutting? Would you say moslty 2d or 3d?
| Howdy, I'm in the same boat as for a need for sign software for routering. I'm leaning towards Mach2 as it works pretty solid. Another that I really like is www.deskcnc.com as it is very intuitive. Just use gray shades for your depth . . . nice. Regards, DaSigntist |
#10
| Intresting..... I would like to know what others use out there in CNCzoneland are using for signage routering. I'm about a week away from a running machine and I'm ready to buy some software. Vfontz and Vcarve are others I'm checking out too. http://www.vectorcam.com
__________________ Regards, Dasigntist Never forget that only dead fish swim with the stream Malcolm Muggeridge |
#11
| DeskCNC has continuous contouring by default. If you want to operate without it, you have to manually turn it off. It is very smooth and has no noticible difference between cutting a single line, an arc or a chain of entities. It has an external intelligent controller card that provides over 40,000 steps per second from a pentium class windows computer via the serial port. It also includes CAM programming capability for pocketing, contouring, and drilling, tracing, engraving, carving, 3D solid machining, etc. Vfontz and Vcarvz were designed as accessories to VectorCam. They have capabilities not included in DeskCNC. Their only function is to create a 3D toolpath that results in a carved contour with corners sharpened with the tip of a V cutter. Both Vfontz and Vcarvz can create lettering from Tru-Type fonts, Vcarvz can also use DXF closed shapes to create raised islands with corner sharpening around the outer as well as inner perimeters. The cutter cuts deeper in sections of the characters that are wide and shallower in skinny sections. The Z depth is varied to exactly match the edges of the cutter with the outline of the letter with a single pass through the center of the letter. Fred Smith - IMService |
#12
| Software automation, and real success in CAD/CAM | Scott_bob | General CAM Discussion | 4 | 07-20-2005 06:19 PM |
| What CAD/CAM software are you using? | marting | General CNC (Mill and Lathe) Control Software (NC) | 11 | 01-29-2005 04:54 PM |
| CAD/CAM Software Help | rustyolddo | General CAM Discussion | 17 | 07-20-2004 09:44 AM |
| CAD/CAM Serial Control Software | AndG | General CAM Discussion | 2 | 05-10-2004 07:43 PM |
| New Virtual Sculpting CAD/CAM software | dcarr | Product Announcements & Manufacturer News | 0 | 08-31-2003 10:18 PM |
