Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
  #13   Ban this user!
Old 03-30-2006, 03:14 AM
santiniuk's Avatar
santiniuk is on a distinguished road
This is something I do in Catia often.
1. Open the .dwg or .dxf with Catia, it should open in the drafting workbench
2. Drag a box around the profile you want and do edit / copy
3. Go file / new / part
4. Click the sketch Icon and select a plane.
5. Go Edit / Paste
You should now see the profile in part design.
6. Do a Tools / Sketch Analysis and make sure the geometry says closed.
7. Exit workbench and you should now be able to make a pad.
Good luck.
Old 03-30-2006, 04:38 AM
*Registered*
lakeside is on a distinguished road
Old 03-30-2006, 05:08 AM
*Registered*
this dxf is the questionable gears just in case file did not got though Mat
Old 03-30-2006, 06:50 AM
*Registered*
Old 03-30-2006, 08:18 AM
*Registered*
Had Some Free Time Here Two More From Your Set Tell Me If And What Size For Step
Old 03-30-2006, 08:29 AM
*Registered*
Here I Just Put Them All In This File We Only Ned To Know About Top Two Right And Well I Guess I Should Do Some Real Work Now
