Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 10-07-2003, 06:48 PM
JuiceMan is on a distinguished road
Sub programming
Macro or sub programming on a older fanuc wire. You know those older wires that don't have much memmory. Anyone have an exsample of a sub that I can use?
Basic application is cutting a gear. I would like to create 1 tooth, and then run the sub to create the rest of them!
Any help would be great. I am looking for exsamples.
Thanks!
Old 10-08-2003, 01:34 AM
Mortek is on a distinguished road
Would'nt you have to keep rotating the material as the subroutine would only cut the tooth in the original position? How limited is your control's memory?
I have a control,(cnc mill) which has a rotate command(G68 x0 y0 90) Does your fanuc control have such a command? If so maybe this is posible.
Old 10-08-2003, 08:19 PM
Would the G68 rotate the work corrodinate? How does this command work?
Also I think I need to use L commands to make the start and the end of the sub, wouldn't that be right?
Thanks for the help
Old 10-08-2003, 08:32 PM
As my control works which is a Milltronics Centurion VI , The above code uses the x,y coordinate as the center of rotation and the 90 was the degree of rotation of the work coordinate. The L command would let you define the # of repeats of the subroutine, therefore the rotation command would need to be in the subroutine. Then G69 shuts off the rotation.
I had a Fanuc 6M control, but I don't remember finding a rotation command. Maybe your control is newer and this option exists. I would call fanuc and see if this is an option on your control and if it will cost you to turn it on. More than likely it will be a different G code.
Programming PLC on Fanuc 0M MetLHead Machine Problems, Solutions , Wireless DNC, serial port 19 06-27-2011 06:47 PM
Mazak C axis programming dpinson General Metal Working Machines 1 07-02-2005 03:06 PM
API Programming Anyone Al_The_Man Computers and Networking 3 02-14-2005 08:31 PM
Learning Programming Gujustud G-Code Programing 15 01-17-2005 04:17 PM
Conversational CNC Programming BlueChip Product Announcements & Manufacturer News 0 07-24-2004 01:37 PM
