eSoles, (www.esoles.com) is upgrading to a 5axis Thermwood CNC. We make custom footbeds using a 3d scanner, edit the data, add some features and generate a NC code. Our current software is ArtCam, which does ok with contour milling. Our plan is to mill a perimeter bevel and add abevel cut beneath the arch.
I'm searching for a 5axis compatible CAD/CAM that will let us import and edit STL files. My choices seem limited (powermill, maybe OnecNC).
If anyone has some suggestions, I would be very grateful.
LinkBack URL
About LinkBacks
