| General CAM Discussion Discuss CAD/CAM software and Design software methods here! |
I'm using a simple cad program called delta cad. Whenever I draw something each line is an individual object. For example if I draw a box it is 4 lines, or 4 objects. Not 1 object. This is causing me big problems with my routout cnc program as it does not understand inside/outside offset on a line. A line does not have an inside/outside. But a box (or whatever shape) does. I have autocad 2000 (just don't know it very well). Does AutoCad have a method to put lines into a single object? Any ideas for me? Thanks, Tom |
| In AutoCAD, use the recangle command or draw a box with the polyline command.
| says you can do it.... don't say how: "You can join a line, arc, or other polyline to an open polyline if their ends touch. If a line crosses the end of a polyline in a T shape, the objects can't be joined. If two lines meet a polyline in a Y shape, AutoCAD selects one of the lines and joins it to the polyline. Joining also causes an implicit decurve, with AutoCAD discarding the spline information of the original polyline and any polylines being joined to it. Once the joining is completed, you can fit a new spline to the resulting polyline." now if it just said how..... |
| Sorry I couldn't get back to you sooner. Use the PEDIT command, which you already figured out.
