| General CAM Discussion Discuss CAD/CAM software and Design software methods here! |
| Well, before I sound like a recording - first I'll ask a question: Do you want to take the .stl file to (CadCAM) so you can mill/cut it - like you want g-code as the end result? [Now the recording part - I'm not associated with IMServ, but like some of the products ] - Stlwork will do that (.stl to gcode) and I think you can try it out before buying it. Or, as another question; Do you want to take the .stl file to CAD to manipulate - clean up - mod etc, then get it to CAM or gcode? Seems like Solidworks ought to get you to that - import the .stl then save/export it to another format as needed. Sorry I'm not at the "workstation" to check out the ins/outs on SW. Jim
__________________ Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it. |
UG will import an STL but you can't do anything with it. You can't do any measuring, you can't use any of the geometry to create new geometry, it's basically a dumb object that you can look at. Quite frustrating because sometimes I need to reverse engineer a part where all we have is an STL file B.Kidd |
"Do you want to take the .stl file to (CadCAM) so you can mill/cut it - like you want g-code as the end result? [Now the recording part - I'm not associated with IMServ, but like some of the products ] - Stlwork will do that (.stl to gcode) and I think you can try it out before buying it." This really did it. I played for about an hour and I have G-code. It is at first a bit confusing when you start from other cam software, but I got code. I will invest in this once I get a bit better at it. |
