Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 12-22-2005, 01:48 PM
bluesky is on a distinguished road
mirror transformation in MasterCAM
I am working on two boeing parts. They are opposite to each other. But, I just have one model. How can I make a mirror transformation in MasterCAM to get the other one? Does anyone have experience on doing this? Please help!
Old 12-22-2005, 02:36 PM
psychomill is on a distinguished road
What version are you using? Do you want the mirrored part in the same file as the original?
You can use " xform > mirror " then pick the an axis or mirror around a line. If the model utilizes a lot of levels, it may be easier to keep track by saving the original as different file first then mirror the entity/entities. If not, you can also create the mirror on a different level at the time of making the copy.
It's just a part..... cutter still goes round and round....
Old 12-22-2005, 03:04 PM
psychomill, thank you for the response.
I need to put "opposite to each other" more clearly. If you have a paper drawing for part A, you will see part B, which is opposite to A, by looking from the back side of the paper.
Right now, I have a 3D model for A, how can I create the 3D model for B in MasterCAM?
I feel it should be some mirror transformation around some axis. But i did not figure out how to do that mathematically.
Old 12-22-2005, 04:07 PM
Rekd's Avatar
Rekd is on a distinguished road
xform/mirror
select geometry, done.
select either X or Y axis, Line, or 2 Points
Done
select copy, OK
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
Old 12-23-2005, 08:20 AM
Yes, it is really simple. I thought it is complicated. Thank you, rekd and psychomill.
Old 12-23-2005, 09:25 AM
Rekd's Avatar
You're welcome.
You can also transform/mirror etc the toolpaths themselves without having to mess with the geometry. But that's a topic for another day.
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
Old 12-23-2005, 02:22 PM
Ain't it always Rekd????
