Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 12-09-2005, 08:55 AM
jamesr is on a distinguished road
Surfcam help
anyone here use surfcam
Old 12-09-2005, 06:00 PM
Kool Parts's Avatar
Kool Parts is on a distinguished road
Oooh ya
Gary
Old 12-11-2005, 04:24 PM
scubanick is on a distinguished road
surfcam
sure do what ya need
Old 12-12-2005, 07:07 AM
iam having problems on running tool paths on trimmed nurb r surface i will attach part to see what you think
Old 12-12-2005, 10:05 AM
Do U Have The Surfcam File That You
Have Already Tried To Run Toolpaths On
I Would Like To See Exactly Which Surfaces You Are Wanting To Machine
The Entire Part Or What
Or Is The Software Just Giving You Errors
Explain A Lil More
Old 12-12-2005, 10:25 AM
it seems like when i pick the surfaces to run the tool on it recognizes it but when you put in tool info it doesnt do anything the surfaces are in yellow running surfcam 2005 no errors are being given either
Old 12-12-2005, 12:03 PM
Are U Using Planar Machining Path To Try Those In Yellow
Or What I Would Suggest A Tapered End Mill With That Radius On It
To Machine That
Let Me Show You How I Would Machine It
I Will Post The File After While
Old 12-12-2005, 01:27 PM
here is the roughing pass i would use on this part
but for finishing those walls i probably would get some tapered endmills to get the small radius in the corners along with the angle on the walls
Old 12-12-2005, 01:41 PM
scuba cant open file saying invalid version number im using 2005 build 120 no maintence
Old 12-12-2005, 02:49 PM
here try this one
  #11   Ban this user!
Old 12-12-2005, 03:10 PM
how do i get that step reduction is it included in the 2005 ?
  #12   Ban this user!
Old 12-12-2005, 04:26 PM
umm
do what seat of surfcam do u have
i have a 3-axis plus seat
and yes it should be in 2005
you can also use Z level roughing
will work the same
but with only one tool where are SRM will can use multiple tools
