Results 1 to 4 of 4
Thread: keeping tool centerline orthogonal to surface
    Registered compositesgal's Avatar
    Feb 2012
    All -
    I don't know if this is the correct forum for my question, but here goes...
    I'd like to be able to acquire coordinates for vectors orthogonal to a part surface at any given point. I'm aware that this is a non-trivial mathematical exercise, but I'm hoping that there's an open source solution.
    Not being an engineer, I'll start with (what seems to me to be) the obvious question. Would FEA software generate this information?
    Any thoughts or suggestions would be appreciated.
    Thanks,
    CC
    May 2004
    Do you know where you are? What planet did you come from? Do you come in peace?
    I think in multi-axis machining terms, you are wanting to know how to keep the tool "normal" to the surface. I am not sure you need advanced algebra to get the needed vectors. The way a multi-axis machine works is you need the point on the part and the a axis and b axis angles, all in relation to an established X0, Y0, Z0 point and the corresponding planes.
    http://www.kirkcon.com/
    Feb 2012
    Thank you for the providing the specific engineering term although normal and orthogonal are synonymous.
    Your answer seems a bit simplistic when describing normality to a complex curved surface. However, I'll give it due consideration. I would prefer a simple direct solution.
    CC
    May 2004
    The simple solution for me is to select a 5 axis milling machine in MasterCam and let MasterCam do the calculations based on the tolerance parameters (resolution if you will) I provide.
    I have actually done the calculations for X, Y, Z, B, C for 5 axis router work. It is just so much waaaay easier to let the software do it.
  1. Need Help!- SL-20 x centerline offset
    By vegas705 in forum Haas Lathes
    Last Post: 03-18-2013, 06:58 PM
  2. Keeping Tool Offsets at Zero?
    By zeeway in forum Mach Mill
    Last Post: 05-18-2010, 08:03 AM
  3. Replies: 19
    Last Post: 09-18-2007, 08:48 PM
  4. Using non-orthogonal axes
    By ChrisLT in forum G-Code Programing
    Last Post: 07-16-2007, 08:57 AM
  5. Keeping the tool down
    By scottsss in forum OneCNC
    Last Post: 10-09-2006, 10:30 PM
