Results 1 to 4 of 4
Thread: I have Haas and Solidworks and need CAM Software
    Jan 2012
    I am a complete newbie at CAM software. I have an R&D shop with two very experienced machinists that have been making great parts for me with a manual Hardinge lathe and a Bridgeport EZ track mill. I just took delivery of a Haas TM-1P mill and ST-10 lathe. I was thinking that we could do the programming conversationally, but that will not quite cut it for the mill.
    Our products are not too complicated from a machining standpoint. They are blocks with holes and threads, valve seats and solenoid stems etc. There is no complicated surfacing. The design work is done on SolidWorks and NX (mostly SolidWorks). We already have solid models for all of the parts. the machinists know some G-code and we have a few guys that write code directly for production parts.
    I want CAM software that I can run from the SolidWorks environment and not too hard to learn. From researching the Haas and SolidWorks websites I fond that:
    BobCad-Cam
    Mastercam
    Gibbs CAM
    Esprit
    May do the trick. Any pros or cons on any of the above packages? Suggestions welcome.
    Cheers,
    Joe
    hub
    hub is offline
    Sep 2010
    Finland
    Also take a look at solidcam, just as an idea. Works great inside solidworks.
    http://www.cnczone.com/forums/cnc_wood_router_project_log/125895-my_diy_cnc_cnc2011_%3B.html
    Jan 2012
    CAMWorks - the preferred CAM partner
    I've heard that CAMWorks is fully integrated and designed exclusively to operate in SolidWorks. It also offers knowledge-based, feature recognition and associative machining capabilities within SolidWorks.
    You could ask for a trial version to start with.
    - Dave
    Monkeywrench Technician DareBee's Avatar
    Jan 2004
    Stratford, Ont. Canada
    HSMworks has a free version that gives you 2.5D.
    Give it a try, until you know what you are doing and then purchase if needed.
    BTW, this free version is extremely good software (I am looking right in the horses mouth).
    www.integratedmechanical.ca
  1. Replies: 13
    Last Post: 03-21-2011, 03:08 PM
  2. New: VisualMILL for SolidWorks - Affordable Integrated CAM Software for SolidWorks!
    By Craig_Preston in forum Product and Manufacturer Announcements
    Last Post: 07-15-2009, 07:43 PM
  3. Cam prog. for HAAS and Solidworks
    By MailleMas in forum General CAM Discussion
    Last Post: 12-20-2008, 11:54 AM
  4. Least Expensive CAM software for Solidworks
    By Adamj12b in forum Solidworks
    Last Post: 12-11-2007, 12:42 AM
  5. FEA software for Solidworks
    By georgebarr in forum Solidworks
    Last Post: 01-17-2006, 10:33 AM
