Results 1 to 2 of 2
Thread: finn power laser turret combo, using nc express
    Jun 2011
    Hoping someone here uses this software and can help me out, company I work for hasn't updated the software or kept thier maintinence agreement up to date, so I get no help from finn power.
    The text marking option will only let me put in text .100 or higher, Why can't I go smaller? I have some parts that I need .060 high lettering, my only option is to draw the lines in, run autotool to laser them, and then edit the contour and switch them to the marking contour. Which is fine, but does take longer than just opening the text marking option and typing in what I need.
    It would be great if anyone has some info on this. Thanks in advance.
    Mar 2012
    Finland
    Earlier NC Express versions had the minimum text height limit in 0.100, as you have found out. Latest released version 11.1 has the limit down to 0.010. Please ask Prima Power for upgrade or maintenance. If you go with maintenance at this point, I would guess you get also the new NC Express 12.1 with ribbon-style user interface in few months with the same payment.
  1. Circulo Rolado Con Mate Roller Ball-Finn Power SG5
    By Morgadoleo in forum Spanish CNCzone
    Last Post: 10-03-2011, 02:30 PM
  2. Need Help!- FINN POWER
    By Antonio Arguijo in forum General Metal Working Machines
    Last Post: 05-24-2011, 08:44 AM
  3. Need Help!- finn power software
    By rocky916 in forum General CAM Discussion
    Last Post: 04-22-2011, 02:41 PM
  4. Problem in FINN POWER MACHINE
    Last Post: 12-13-2010, 04:28 PM
  5. Roller Circle using Mate Roller Ball -Finn Power SG5
    By Morgadoleo in forum General Metal Working Machines
    Last Post: 07-12-2010, 12:11 PM
