Results 1 to 12 of 12
Thread: Testing waters: Cambam, ArtCam and Meshcam. What others are worth trying?
    Dec 2011
    So far I have installed trial versions of cambam, meshcam, and artcam.
    I will be using autocad 2012 and solidworks to generate my models. I have gimp to do my art work if necessary.
    I purchased a Romaxx HS1 in december, should be here next week. Been lurking the forums and signed up last month. I will be running my machine with mach3. Purchased my bits and precision collet from precisebits.com
    The 6 week lead time has allowed me to play with the software some.
    My thoughts so far:
    Cambam -
    -archaic looking
    -pricey when you compare it to meshcam/artcam feature set
    -more tedious to get results
    -lots of settings
    -not very easy to move around
    Meshcam-
    -Very intuitive
    -Does 3d, flip, 4axis
    -Creator has a nice forum, blog and is active on forums
    -Takes in customer feedback and updates the program
    -From start to finish the process is very step driven and easy to do
    -Price is good for the feature set. May even be able to run MicroCarve instead of opting for Meshcam Art
    Artcam Express-
    -Lots of features
    -Modules that you can add are nice but are very $$$$$$
    -Does not appear to do what I need it to do with 3d stl models.
    -Menu overload when compared to meshcam. Just too many things to learn at once.
    -Required internet explorer 8 to be installed. Meh. Probably so they could have all the purchase options in the demo which was annoying
    So far I am looking at pulling the trigger on meshcam. Any other software I should try out that are similar to meshcam?
    Dec 2011
    Going to give FreeMill a whirl too.
    EBC
    EBC is offline
    Registered EBC's Avatar
    Mar 2008
    Col La Choya, Los Cabos,Mexico
    vectric...
    vector studio 22
    servicio de fresadora cnc
    Dec 2011
    Any worth mentioning about vectric? Does it compare well to any of the already mentioned softwares?
    Dec 2011
    Meshcam.....it would be nice if you imported PLT files.
    Mar 2003
    Shelby Twp, MI....USA
    Meshcam imports 3D "meshes", either .stl or .dxf.
    Or, it can create a 3D mesh from an image file.
    PLT files are 2D files, and MeshCAM isn't a 2D (2.5D) CAM program.
    MeshCAM can only use 2D files to define machining regions of the 3D files.
    Dec 2011
    I just need a way to do text engraving too.
    Looks like the price of meshcam went up.........ugh
    Mar 2003
    Unfortunately (for you), that's just not what MeshCAM was created to do.
    You might want to check out Stickfont, which might do what you want, and it's free.
    Jul 2011
    For text engraving you could use DeskEngrave from DesKAM CNC Home
    There is more to test: CAM Products
    I narrowed my search down to Meshcam as well.
    Registered LeeWay's Avatar
    Jun 2004
    I have an old version of Meshcam and Vectrics Cut 3D. I like the later better, though both work well.
    Vcarve from Vectric does text well also. You can bundle Cut 3D and Vcarve, but not cheap.
    I do think it is a worthwhile investment though, even for a hobbyist.
    Lee
    May 2006
    Try SheetCAM too!
    Jun 2004
    It is the one I use the most for 2.5D stuff. Excellent and fast.
    Lee
    1. Need Help!- artcam 2010 examples to artcam 2008
      By mishu28nmv in forum ArtCam Pro
      Last Post: 06-15-2011, 01:27 PM
    2. Replies: 0
      Last Post: 03-08-2011, 06:28 AM
    3. Testing waters for anodizing special
      By MBG in forum CNCzone Club House
      Last Post: 12-26-2009, 11:53 AM
    4. Meshcam?
      By fattuna in forum GRZ Software- MeshCAM
      Last Post: 10-13-2004, 03:19 PM
