Results 1 to 2 of 2
Thread: FreeMILL help needed by newbie
    Nov 2011
    Not sure if anyone can help but I am trying to generate g-code for a part requiring 3 axis. I modelled the part in Solidworks and then downloaded FreeMILL. My machine runs Acurite MillPWR.
    I have imported my part and it all looked good, picked up that the part was 232mm X 150 X 12.5mm but when I ran the code, it only made a part approx 9mm 4mm.
    Have tried multipule times, uninstalled and reinstalled, but keep getting the same result.
    It is like it has scaled it down but there is no facility for me to change the scale.
    Am I expecting too much from freeware...any suggestions of other software?
    Any suggestions greatfully accepted. Cheers
    Apr 2004
    Oakland CA USA
    STL files don't specify what units are used
    It sounds like Freemill is taking in your millimeters, and trying to translate them into inches, but is then outputting mm instead - multiply 9 x 25.4 and you get pretty close to what you were starting with. So look for the mm/inch settings and change the output units to mm; that should fix the problem (this could be happening because you're using the wrong post-processor). If that doesn't work for some reason, go back to your original CAD program and scale everything up by a factor of 25.4.
    Andrew Werby
    ComputerSculpture.com — Home Page for Discount Hardware & Software
  1. Inventor to Freemill
    By mishawaka in forum Autodesk Software (Autocad, Inventor etc)
    Last Post: 01-09-2012, 05:18 PM
  2. FreeMill
    By CNCadmin in forum Visual Mill
    Last Post: 07-28-2011, 03:11 PM
  3. Need Help!- Freemill 2-sided milling
    By Gosa in forum General CAM Discussion
    Last Post: 07-09-2010, 04:55 PM
  4. Need Help!- FreeMill Errors
    By BlueFin in forum General CAM Discussion
    Last Post: 06-14-2010, 11:05 PM
  5. Can you resize in Freemill?
    By teamtexas in forum General CAM Discussion
    Last Post: 02-23-2009, 09:15 PM
