Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 10-26-2005, 10:01 AM
SamLS is on a distinguished road
Rock and Stone faces
I need to generate a solid model for some molds which are split rock and stone. Like a castle wall. I need to generate the rounded chipped surface so I can make a mold. What software should I be looking at to generate these types of surfaces to be machined. I'm looking for something canned that would take alot of time on my part editing the surfaces. Thanks
Old 10-27-2005, 04:21 PM
dcarr is on a distinguished road
I don't know if there is anything that is totally "canned". But I sent a few minutes using VS3D to come up with this:
I started with a rectangle, added a bevel, some random texture, and a few ridges and depressions. Once I had a rock finished, I stacked three of them and then did an automatic nesting (Allowing 180 degrees of rotation). So all the rocks in the wall are the same, but some are actually inverted. All in all, it took less than 10 minutes to build the surface.
I assume you are interested in carving concrete forms ?
VS3D home page: http://www.designscomputed.com/vs3d
Daniel Carr - President,
Designs Computed, LLC
Old 10-27-2005, 04:56 PM
This looks like it may get the job done. Can I do such from a digital picture or BMP file? Thanks
Old 10-27-2005, 07:18 PM
Yes, if you have a digital photo (BMP, TIF, JPG, etc) you can convert the image brightness to surface height. Like this:
http://www.designscomputed.com/vs3d/...mg_emboss.html
Old 10-27-2005, 09:22 PM
whiteriver's Avatar
whiteriver is on a distinguished road
If you have software for creating a height field from a bmp the I would suggest getting Dosch 3d textures for Stone and Concrete. They contain bumpmaps which is a correctly greyscaled bmp.
http://www.doschdesign.com/products/...ncrete_V3.html
Donny
www.whiterivermfg.com
