Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 08-07-2003, 03:26 PM
Location: Korostenska str. 76, 12300 Cherniahiv, Zhitomir reg., Ukraine
igorko is on a distinguished road
Milling a hole
Dear All,
My newbie question is about G41, G42
Is it possible to mill a hole 8.4 mm in diameter with 6.5 mm endmill using G41 (G42)?
The hole is 20 mm deep.
If so, could you, please give the sample code.
I am using FANUC-OM control.
Thank you very much in advance.
Yours, Igor Kozlov
With kindest regards, Igor Kozlov
Old 08-07-2003, 04:21 PM
Jennifer's Avatar
Jennifer is on a distinguished road
Igor -
I really don't see how you could do this...the diameter of the tool is too large. You'd need to use a tool whose diameter is less than half the size of the hole (when you enable the G41 (or G42) the tool will step out the distance of the radius).
Maybe someone else has an idea?
Jen
Old 08-07-2003, 05:19 PM
HuFlungDung's Avatar
Moderator
You don't have to use full tool radius comp, you can use wear comp instead. This means program the toolpath at the proper offset for a given tool, and then use compensation for tweaking the exact diameter you get after you trial cut it.
The amount of tool movement when the wear comp amount is applied is not large, and the approach should easily fit inside that hole (with enough magnification to see what you are doing
Old 08-07-2003, 05:46 PM
Mortek is on a distinguished road
Many of us are used to drawing an offset ourselves, confusing the issue here. Using cutter comp your toolpath would be, if drawn, the actual outline of the hole. Thus the machine would do the offsetting meaning the cutter would only move over the size of it's radius, allowing it to still easily fit inside of the 8.2 mm hole. Yes it could be done very easily.
CAMmando's Avatar
CAMmando is on a distinguished road
What he said ...
.2559 inch dia end mill cutting .31496 inch dia hole.
O0001 (MILL HOLE INCH UNITS)
G90 G17 G40 G49 G80
(CONTOUR)
T1 M6
G0 G54 X0. Y0. S1000 M3
G43 H1 Z2. /M8
Z.1
G1 Z-.196 F.5
G41 D1 X-.0295 F1.
G3 X.0295 I.0295 J0.
X-.0295 I-.0295 J0.
G1 G40 X0.
Z-.392 F.5
G41 D1 X-.0295 F1.
X-.0295 I-.0295 J0.
G1 G40 X0.
Z-.588 F.5
G41 D1 X-.0295 F1.
X-.0295 I-.0295 J0.
G1 G40 X0.
Z-.784 F.5
G41 D1 X-.0295 F1.
X-.0295 I-.0295 J0.
G1 G40 X0.
G0 Z2.
G91 G28 Z0. M9
M30
CAM teh "metricschmetric"
You could also use helical interpolation (G3/G2 with a Z value).
Wee aim to please ... You aim to ... PLEASE.
Old 08-07-2003, 05:52 PM
Proof is in the pudding, good job Commando.
Old 08-07-2003, 05:59 PM
Moderator
No room for an approach that way, is there Mortek? I think that is what Jen was thinking, too. There is no room for full cutter radius comp to be applied unless you can do it before the tool enters the hole.
Old 08-07-2003, 06:13 PM
Plunge center of hole and move out to toolpath, try backplotting commando's code and you will see. So yes a very small approach, one would have to be careful if hand programming this.
Old 08-07-2003, 06:17 PM
Moderator
CAMmando's code is using a small radius toolpath which is an offset path from the hole circumference. At least that is what I see.
Old 08-07-2003, 06:33 PM
wms's Avatar
wms wms is offline
Moderator
wms is on a distinguished road
HU,
From what I see, Cammando's D1 offset value would be 0.
He has taken the difference between the hole diameter and the tool diameter, divided by two and that equals the x-.0295.
Old 08-07-2003, 06:37 PM
Rekd's Avatar
Rekd is on a distinguished road
Correct. I program exclusively this way. It will work, just use 0.0 for your CRC, unless you're using a re-grind or it's a tight tolerance, in which case go + a bit then cut, measure, adjust and cut again.
'Rekd
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
Old 08-07-2003, 06:38 PM
Moderator
Yes, Ward, I know. But Mortek seems to be saying that the toolpath would be the actual outline of the hole, and I'm saying it isn't.
Thread milling, can anyone help jtrav General CAM Discussion 16 03-06-2006 02:25 PM
Why would this machine be bad for milling? jevs Knee Vertical Mills 5 06-16-2005 10:49 PM
Heads Up - Article about building CNC Milling Machine samualt CNCzone Club House 3 06-13-2005 02:43 PM
G12/G13 hole milling JFettig Mach Software (ArtSoft software) 14 03-10-2005 08:23 PM
Thread milling cutterdia / hole ratio HuFlungDung Machine Problems, Solutions , Wireless DNC, serial port 3 12-31-2003 08:44 PM
