Results 1 to 7 of 7
Thread: cam software
    Sep 2011
    england
    cam software
    Hi I am running a busellato jet 3000 with genesis 2.1.4 and would like software for engraving fonts. Can anyone recomend software that would output to the correct file ext that is required for my version of genesis. Also could anyone tell me what this file ext should be. cheers
    Sep 2011
    font engraving
    Hey I run a busellato jet 4002xl. it runs genesis but cant think of version right now. I got a program off internet called desk engrave and loaded it on my machine. it will take any font installed in the computer and make a program that runs around the outline of the letters. if your letters have holes in the center like an O it will go around the outside and inside making 2 lines. also if you dont select a font it will make stick letters. It outputs the file in DXF format and you can use the autolink dxf option from the menu in your program editor that you should have with genesis. thats what i do anyways. good luck
    Sep 2011
    england
    Thanks for the reply i have downloaded the software and it has worked fine, the only problem i have with it is that after importing it to genesis it has the best part of 2000 lines and no tool assigned. Is there an easier way of inputting tool number without doing them 1 by 1 cheers.
    Sep 2011
    desk engrave
    glad it worked. when I use it to make signs and stuff it also comes up with high numbers of lines of code. you can change it to make more lines (more precise) or less lines (more blocky letters) in the options. but anyway, all you should have to do to put tools in is tell it what tool to use at each setmill not every line. at least thats what i do on my machine. i start a line with a setmill and add as many linear millings as i want. it uses the same tool untill i put in another setmill to start a new line. hope this helps
    Sep 2011
    oh i checked my version of genesis and i run 2.2.16 on my jet 4002xl the jet 4 i sometimes run has a lot newer software on it.
    Sep 2011
    england
    ok cheers so i can make it less lines still quite alot though, the problem is on all of the curves it puts hundreds of set points so still have to input tool on most lines. I guess this is not a massive problem though just takes a bit of time, at least i can now machine text cheers again.
    Sep 2011
    that's weird. your machine must convert it different than mine. when I use the program it makes one setmill for the outside of the letter and one set point for the inside of the letter. Mine also come up with a hunderd lines or so for each letter but only a few setmills. well good luck any way.
    1. Newbie- Need software advice...What software can import .JPG files?
      By pairofjacks in forum General CAM Discussion
      Last Post: 06-01-2011, 07:18 AM
    2. Build Thread- machine control software & cam software
      By grttt3 in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 05-06-2010, 02:49 PM
    3. Just IN- MIE Solutions - Free Quoting Software Trial Software available
      By MIE Solutions in forum Product and Manufacturer Announcements
      Last Post: 01-07-2009, 11:42 AM
    4. First post in the software dept. Free cnc software?
      By runinbymdnt in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 02-06-2007, 10:49 PM
