Page 1 of 2 12 LastLast
Results 1 to 12 of 24
Thread: CNC punch press software
    Sep 2005
    I am helping review CNC punching/nesting software suites for my employer. From what I have read this forum deals more with CNC milling than anything else, but most of the posters seem extremely knowledgeable so I thought I would ask a couple quick questions:
    We currently use Sigmanest to nest for our lasers. Does anyone have any experience with their newer punch module?
    We are also looking closely at Radan, and possibly Stryker. Any information/user experience with these?
    At this point we have an engineer that does all the CNC punch programming by hand, using CAMBridge (I believe).
    Our applications are strickly 2d, we export flats out of SolidEdge.
    If there is a more applicable forum I should be posting in, please let me know. Thanks!
    Registered buscht's Avatar
    Nov 2003
    I haven't programmed CNC punch presses in over 8 years, but we used Stryker systems within AutoCad. It worked very well and we were happy with it and the company. They worked diligently to develop our applications.
    Good luck
    Sep 2005
    Thanks for the reply! I'll keep learning as much as I can about all of them in the meantime.
    Mar 2005
    I'm looking for the same thing too.
    My die set is my own design. It uses 28xx punches and dies from CE Tooling and makes them for use in a OBI type stamping press. I had Minister build me a 35 Ton press that works real well. They built it using my own specs. I originally had a HEIM Rouselle G1-55 which was too big, and another Minister and Rouselle that were both too small (kick presses) that used a foot pedal to operate. I needed one that used a 2-1/2 foot x 1-1/2 die space.. and did single station punching, but easily allowed both punches to rotate in 1 to 5 deg increments through the full 360°.
    I considered having AMADA make me a press but that was too $$$$$$$$$.
    Greg
    Oct 2005
    Take a look at metalsoft I have seen them work on amada and trump punch and laser
    I use tops 100 and 300 from trumpf
    Mar 2005
    I think MetalSoft is a AMADA company.
    I'll try that thought.
    Greg
    Sep 2006
    Hope I am not too late!
    I love these questions and I hope everyone reads with an open mind because I have been around the block with punching software. Although I have never used Sigmanest I hear that they do a really good job with lasers and plasmas however they struggle in the punching area. In the past I have used SmartCam (not good for newer machines) and Optimation (reduced programming time at the cost of increased cycle times) and currently I use Wittlock Engineering software WE-CIM that is driving all the machines were I work. (a key issue with any software you look at). Recently I have found that I can generate programs faster than Stryker. If you only have one machine and you never plan on buying any other type buy what the machine builder recommends.
    Wittlock Engineering: http://www.wittlockeng.com/
    I would highly recommend you look at Wittlock Engineering if you truly want to drive any sheet metal equipment, have the flexibility to change and customize to your daily needs. Take a look at my home page for some examples of custom code and custom reports generated from WE-CIM.
    Greg
    Home Page: http://www.ctcn.net/~3kings
    Aug 2009
    New Zealand
    Hi everyone, I work for a firm in New Zealand that produces food display cabinets and we have a Trumpf 2020R, A job has become available nesting parts on sheets and I was wondering if anyone had any information they could share so I could have an advantage in the interview. We use tops software.
    Sep 2006
    Post
    Trumpf has what they call "Free Geometry Nesting". I would recomend that you have this if your going to be nesting a large amout of differant shaped parts.
    Independent CNC Programmer
    www.independentcnc.com
    My mission is to share CNC programming innovations for a lifetime.
    Registered adamshive's Avatar
    Jun 2009
    Lightbulb We use Striker
    You have to hold Striker's hand A LOT until you get it down. There are many, many presets and configuration parameters to set. There are also many functions that are totally useless and even striker reps themselves will admit that. It took me about 6 months to get the hang of it. Now I can bust out very good to excellent programs in a breeze. The striker systems tech support is absolutely top notch.
    This is the only program I've used and I have to say I'm about 75% sure that I like it.
    Some of the other engineers say that Metalsoft is pretty good. Keep in mind that with Striker Systems you need a valid version of AutoCAD. And no, you can't get around that. Striker runs as a plugin, or add-on which means the ss-punch (the striker systems cnc punch program) will only exhist/run while AutoCAD is running.
    The tech support and company are really honest, even the salesmen. They won't sell you something you don't need and will really help you to make a more efficient process. Don't get ss-nest right away, wait and see if you need it.
    Also if you have Inventor there are a few complicated steps to learn but you can unfold and export the .idw's through a program called "Partshare." It's touchy though, because engineering will need to set parameters and draw in a flat environment before adding radii.
    If you have any more questions about Striker feel free to ask me. I use it all day...
    Sep 2006
    Post Nesting software
    Down side to Striker is it runs inside of AutoCAD. If you are wanting a package with nesting take a look at We-CIM, JetCam, Optimation or Sigmanest. Sigmanest does not have a very good punching solution.
    Aug 2009
    New Zealand
    What Im after is any sort of documentation (user manual etc ) that I could revise to give me an advantage over other candidates, there is probably less than 10 people that use tops in my city so any sort of advantage is going to help wonders. Ive tried searching the net and have only been able to find a promotional .pdf from the Trumpf website.
    Cheers
  • Page 1 of 2 12 LastLast
