| General CAM Discussion Discuss CAD/CAM software and Design software methods here! |
hi every body so i'm new in cnc and i've a new isel cnc milling machine. I want to buy a cam software. Isel have one: isy-cam but it is expensive. I want to know if i will buy an other cam software i will be able to excute working directly from this program or i must use the isel software?? Thank you for your help |
| There is a good program called Galaad that will interface directly with the ISEL even to the point of running it http://www.galaad.net/home-eng.html
__________________ "A Helicopter Hovers Above The Ground, Kind Of Like A Brick Doesn't" Greetings From Down Under Dave Drain Akela Australia Pty. Ltd. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
What have you been quoted on? IsyCAM 2.5+, 3.0 or the latest 3.2 version. If its only typical 2D milling your after, then the cheaper IsyCAM 2.5+ is the one to go for. Any 3D machining and you will need 3.0, or ideally 3.2. Yes the likes of Galaad are cheap and cheerful, however IsyCAM 3,2 is a complete 2D/3D CAD and CAM system, comparable with the latest solid/surface modellers, and high end CAM software. If you need more information on the software, please ask. Alec Thorne Schott Systeme GmbH www.schott-systeme.com info@schott-systeme.com |
