Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 09-20-2005, 06:20 AM
mikie is on a distinguished road
How too Question
Hi All,
i want to route so that the text that i write is raised.
Can any one advise me of the best method to complete this.
my thoughts were:
- write the text
- invert the black/white
- put through some rastor to vector processor
- make gcode
Also,
when i create rastor to vector, (using turbocad), i find that i have to do a lot of manual work on the image, actually, i think it would be quicker to just trace it.
Is this the norm or are there better programs that can do this function.
Can they also be used to do 3D objects?
/Michael
Old 09-20-2005, 07:40 AM
jderou is on a distinguished road
When I do this using Bobcad, I make a rectangle that is the edge of the board, put the text on the board (the outline of the text is made up of vectors). I then initiate the pocket command and select the rectangle as the pocket, then select the text as 'islands' and it does the rest.
Not sure if any other programs work similarly.
Here is a sample of what it does.
If you try to make everything idiot proof, someone will just breed a better idiot!
Old 09-21-2005, 01:56 AM
That sounds so easy.
I'll have to look into bobcad and see how expensive it is
thanks
Michael
Old 09-21-2005, 06:17 AM
ger21's Avatar
Try downloading Elefont, http://www.armanisoft.ch/webdesign/elefont/Elefont.html
and MeshCAM, http://www.grzsoftware.
You'll need to bring the Elefont .dxf into TurboCAD and explode it before it will work with MeshCAM, but it should work.
Old 09-21-2005, 02:55 PM
dcarr is on a distinguished road
VS3D can do it as well.
1. Sculpt the text using any true-type font. Plateau, bulge, and/or chisel it to the desired height.
2. Choose the cutting bit geometry and existing material height.
3. Run a "Contour XY" tool path to pocket out around the letters.
VS3D will show you the path like this:
http://www.designscomputed.com/files/test_carve_1.jpg
And then you will see what the material will actually look like after the tool path is run:
http://www.designscomputed.com/files/test_carve_2.jpg
From this, you can see that the step-over spacing would need to be a bit smaller to clean up all the ridges left by the ball-end cutter.
Daniel Carr - President,
Designs Computed, LLC
Old 09-24-2005, 08:46 AM
Thaks Daniel for your post.
I will look through the links you supplied
/mikie
