| General CAM Discussion Discuss CAD/CAM software and Design software methods here! |
Ok, I like to consider myself to be fairly smart. Neither of the on-line tutorials for beginners works so I have been referencing the manual and going on my slight memory of working with older cad systems...like 10 years ago. I've figured out how to place objects and rotate etc... that's no problem. I'm having trouble adding points after exploding and extruding an existing object. Lets say I connected up 6 lines, I group them as one object then want to extrude them to become a 3D object .375" in depth. I can't figure out the method to do this. I've tried playing with the extrusion tool but can't get it to do anything except place an x on the screen. I also tried a different approach where I placed a box and sized it appropriately making it .375 thick but now I need to place new points in the box to change the shape then move the two points face and back in the same motion so the front and back remain the same shape. Is there a tutorial somewhere that takes you through the basic steps on up? I'm dying here ![]() I took a peek in the TurboCAD/CAM discussion but there ain't much going on over there. Thanks! |
Turbocad is the hardest and most difficult CAD package that I have EVER seen. That is why I have a new copy of AUTOCAD sitting here to be installed on my machine. In my opinion, throw the Turbocad out the door, and find something else as a cad package. You can sometimes do something once in TC, and try to do it again in a drawing and it will not work. I have had to perform a function, save the file, exit the drawing, re-enter the drawing in order to get the same function to work a second time. Jerry |
Is the help file any good? Look up the extrude command and see if it has any info. I don't use TurboCAD, but in AutoCAD, you can extrude a "group" of objects. Only single closed objects. Try to find a way to join them together into a single object before extruding.
Here are some tutorials. http://www.caddigest.com/subjects/tu.../tutorials.htm
| Great! I just bought TurboCAD he he. Oh well....I only paid $26.00 on ebay. I suppose I'll need to find a better package. The manual is large but not very helpful. It really doesn't tell you how to use anything, it just tells you what they do, not actually how to do it. THanks for the link ger21, I did indeed see those tutorials but unfortunately they assume you have experienc with TurboCAD to begin with. Is AutoCAD the package to get? I'm really limited on budget, is there a version that is good but cheap on ebay or used or something? Thanks. Darren |
__________________ cadfish http://www.burgiengineers.com/ |
| I'd personally try DesignCAD. It's what I used before we got AutoCAD at work. When I used it, it was infinately easier to learn than the copy of TurboCAD we had at the time. It's currently sold by the same people (IMSI), but was developed by others. I think IMSI is the 3rd or 4th owner of it. Try the demo and see. It's very easy to use. The only cheap AutoCAD is LT, which is still $500 and no 3D.
| Thanks, I'll give DesignCAD a try... downloading it now. Is AutoCAD just not great quality or something? It seems limited in functionality. Maybe it's just that it is hard to figure out. Thanks again guys. Keep the suggestions coming. |
#10
| I really don't know what you guys are moaning about. It is usually user error which causes programs to screw up isn't it?! Darren, nobody said CAD was easy, you just gotta stick at it. I drew this yesterday, believe it or not, with Turbocad 10.
#11
Like I said, I used to use DesignCAD. Although the newest version of DesignCAD has a lot of similar features to AutoCAD, it can't compare when it comes to stability, speed, customization, and a lot of other areas
#12
| Kong, I sure wish I had a tutorial to get me started. I have TurboCAD Deluxe 10 and have no way to really learn. The manual tells you what things do but doesn't tell you how to do them. The extrusion tool doesn't seem to work, I've joined 6 lines to form a plane, grouped them, then tried to extrude and can't get it to do anything. The features I need seem to be there, I just can't get any of them to work. I used to use old 2D cad systems 10-15 years ago but they were dos based and I only used keyboard commands and a tablet/pointer. I'm very rusty. A tutorial of basic operations would be wonderful but the ones on the TurboCAD site don't work. I downloaded DesignCAD and got much further with it but it seems a bit limited. It might just be me. I was able to extrude but it seems a but cumbersome to place and rotate objects. I don't see a xpos, ypos, and zpos anywhere. Maybe I just missed it. I'm going to try and play some more today with both. |
