Results 1 to 10 of 10
Thread: CAM Software Selection
    Aug 2005
    UK
    Over the last few years I've used many CAM packages but never really stuck with one of them. I've tried MasterCAM, FeatureCAM, BobCAM, SolidCAM and I have also looked at a few on the web. Now the time has come because I no longer have access to the software to purchase my own.
    I'm using Mach3 as my CNC controller so one of the selection critria is the Mach3 post processor. Also I currently have a CNC milling machine and at some point would want a CNC lathe so the software would have to do both....at some point. The milling is most important at the moment.
    Also cost is a factor. If possiable less than a £1k.
    What do people think would be a good selection? User friendly and rapid output would be good. Also imports Solidworks models
    I have been looking closely at OneCNC and SprutCAM are these good contenders?
    Thanks,
    Ant
    Dec 2007
    I use Dolphin CAD CAM and like it quite well. However, if you are looking to import solidworks models, look at sprutcam or visual mill.
    Registered Wayne M B's Avatar
    May 2011
    Could you tell me if I put mach 3 on a main computer with the g cod can i down load this to a memory stick and transfer it to a computer that is chooked up to the cnc router?
    Dec 2007
    It should work if I am understanding correctly.
    May 2011
    Thank you , I'm very new here and I'm checking into everything just to try to be safe.
    Feb 2011
    UK
    I've just taken a look at my copy of ArtCAM Express and it has a few Mach3 post-processors. There's a File Import module available which enables you to import SolidWorks Part files (*.sldprt and *.prt), as well as a bunch of other surface models.
    Although I can say that I'm finding the software easy to use, I can't comment on that particular module as I didn't buy it. The combined cost of Express and that module is well under your budget though, so it might be worth you taking a closer look.
    Hope that this helps you out!
    Monkeywrench Technician DareBee's Avatar
    Jan 2004
    Stratford, Ont. Canada
    VisualMill
    www.integratedmechanical.ca
    Jun 2011
    malaysia
    personel selection
    hi,
    for me software that a newbie like me can operate are the best coz I'm still struggling with my autocad drawing.
    Jul 2011
    If you are using SolidWorks, why would you not consider an integrated CAM solution?
    I use SolidCAM and although it's not the cheapest option, my initial investigations certainly taught me "you get what you pay for"! I found some of the cheaper options such as VisualMill and BOBCAM were missing basic features and were frustrating to use.
    Jun 2011
    malaysia
    yeah my boss did mention solidworks but to look for other competitive solution. anyway tq.
    Quote Originally Posted by Aussie_CNC View Post
    1. Newbie- software selection?
      By RebelTaz in forum OpenSource Software
      Last Post: 08-12-2010, 06:28 AM
    2. Narrowing the CAM Software selection for my Application (Heeeelp!)
      By designerpatrick in forum General CAM Discussion
      Last Post: 10-31-2007, 01:55 PM
    3. CAM software selection
      By mccafferty in forum General CAM Discussion
      Last Post: 01-25-2006, 12:09 AM
    4. CAM Software selection help;
      By fyffe555 in forum General CAM Discussion
      Last Post: 07-25-2004, 10:13 PM
    5. Computer and software selection question
      By Darren_T in forum DIY CNC Router Table Machines
      Last Post: 02-24-2004, 12:32 PM
