Results 1 to 6 of 6
Thread: Tangent plotting / CNC software (rotary cutter) * reward offered!
    Jun 2010
    Channel Islands
    Hi
    we've had a slightly custom machine built by Marchant (more about them later). It's a TANGENT rotary cutter for fabrics. Now the problem is we're using:
    Corel draw to trace the shape
    Sheetcam to lay it out
    Mach3 to cut and control
    Can we not scrap all of the above and just have a nice and simple plotting program to do all of the above? I'll even send the best suggestion provider a £50 drink!
    Alan
    Jun 2010
    Channel Islands
    Ahh, almost forget to explain the problems we're having! Any curves are very 'jerky' to say the least. I'm sure a more dedicated piece of softwre would eliminate this issue?
    May 2006
    First thing you say "trace" the shape,
    Is that from flat paper pattern to cad?
    You can just lay a pattern flat and get a digital camera and photo it, (with grid lines to scale to) load the picture into Mastercam Art and allow it to trace automatically then with some cleanup produce the machine Gcode etc.
    Are you big-time enough to afford the correct systems or a hobbyist? New at CAD/CAM?
    Been doing this too long
    Jun 2010
    Channel Islands
    We're happy to buy whatever is required - we're on to our second machine and haven't cut so much as a finger!
    May 2008
    Have you tried CV setting in Mach3 instead of exact stop.
    Or add a G64 at the beginning of your code
    Jeff
    Registered BobWarfield's Avatar
    May 2005
    Don't know sheetcam, but could be the shape is simulated with a lot of little line segments and that is causing the jerkiness.
    Cheers,
    BW
    Try G-Wizard Machinist's Calculator for free:
    http://www.cnccookbook.com/CCGWizard.html
    1. Need Help!- 4th axis control in EMC2 (Tangent knife cutter)
      By EduardKieser in forum LinuxCNC (formerly EMC2)
      Last Post: 06-27-2011, 01:22 PM
    2. software to convert spline curve to tangent arcs
      By foxfx in forum General CAD Discussion
      Last Post: 05-05-2010, 04:43 AM
    3. I need some help with creation ct1200 cutter plotting vin ..
      By ahmadobayat in forum Printing, Scanners, Vinyl cutting and Plotters
      Last Post: 03-18-2010, 03:42 AM
    4. Software for cutter
      By soko in forum CNC Wire Foam Cutter Machines
      Last Post: 07-08-2009, 06:29 AM
    5. Software help for 2 axis with rotary (foam)
      By DanOSB in forum Carken Products (Deskam, DeskCNC etc)
      Last Post: 03-02-2009, 06:30 PM
