Results 1 to 3 of 3
Thread: Advice on software that suits needs.
    Feb 2011
    UK
    Hi
    I've recently purchased a CNC router, with the intention of cutting out basic 2d shapes from 18mm MDF.
    I am looking at cutting my material(mdf) to the finished size on dimension saw and then using the cnc router...remove one corner with a radius.
    so I'm looking for some guidance as to software that might best suit my needs.
    my machine came with ucancam (yes a cheap Chinese router, newbie) and i can do everything i need to do within this program. the only problem i'm having with this program is that if i enter the material size as 800mm x 800mm and place an toolpath in the upper top right of the material, the router for some reason always starts at x0y0 .
    the g code doesn't seem to contain the start-point.. if you get what i mean.
    anyway, thanks for your time
    mick.
    Registered M250cnc's Avatar
    Sep 2007
    England
    Hi Mick
    Can you post the gcode & a dfx file before you go rushing to spend more money
    Phil
    Sent from my HTC Desire using Tapatalk
    Feb 2011
    UK
    many thanks for your reply...
    I dived in and purchased v-carve pro... and I've got to say its impressive, managed to create what I wanted in minutes & have the machine dancing
    got a new problem now backlash well I suppose there's one good thing with all these problems I'm learning ...
    does nc-studio have backlash compensation do you know??
    many thanks for taking the time to respond.
    mike.
  1. Software advice
    By cindysilas in forum Want To Buy...Need help!
    Last Post: 06-05-2010, 09:27 PM
  2. need advice on cad/cam software
    By slatosky in forum Want To Buy...Need help!
    Last Post: 02-28-2010, 01:56 PM
  3. Advice On OEM CAD CAM CNC Software
    By whoafat in forum General CAM Discussion
    Last Post: 11-26-2007, 05:24 PM
  4. Deskcnc CAM software advice
    By StephenSebastia in forum General CAM Discussion
    Last Post: 06-25-2007, 05:07 PM
  5. Software advice please
    By rval in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 04-20-2007, 06:05 AM
