Results 1 to 2 of 2
Thread: Rounded cylinder intersection G-code
    Jan 2011
    Brittany
    Hello,
    How to make a rounded (constant radius) on the intersection of a hole on a cylinder?
    And most importantly, how to generate G-code?
    Thank you for your replies ...
    May 2008
    uk
    Quite easy to draw in ViaCAD - see attached picture.
    How you cut this will depend on your CAM program.
    I use CamBam and it would cut whichever of those two shapes you send to it as an stl file.
    Martin.
    Attached Thumbnails Attached Thumbnails Rounded cylinder intersection G-code-capture.jpg
  1. Newbie- 3D sketch from intersection curve
    By atlantic23 in forum Solidworks
    Last Post: 10-03-2010, 03:48 PM
  2. square corners getting rounded off
    By SatanKlawz in forum General CAM Discussion
    Last Post: 06-29-2010, 09:33 PM
  3. Error 509 arc lack intersection
    By dresda in forum Milltronics
    Last Post: 11-02-2009, 05:23 PM
  4. rounded corners
    By jc286006 in forum TurboCAD/CAM
    Last Post: 06-25-2006, 01:04 PM
  5. Rounded corners...
    By saturnnights in forum SheetCam
    Last Post: 02-13-2006, 02:06 PM
