Results 1 to 4 of 4
Thread: Which CAM software... what else?
    Registered Tom Siler's Avatar
    Sep 2009
    Sooo....
    I built a CNC router table about a year ago, and so far it's exceeded my wildest expectations. However, the CAM software I started with is clearly not getting it done. Here's what I have:
    3 axis machine 5' by 2' cutting area
    Gecko G540 drive
    Mach 3 running on the controller machine
    Vectric Cut3D and Vcarve Pro
    Rhino
    I really like drawing in Rhino. I have tried a few different packages and I'm extremely comfortable with it. Most of my work is 3D, milling female molds for composite model aircraft parts. Cut3D is normally what I use to generate Gcode for Mach3 to run, but it's limitation of only doing horizontal finish toolpaths is getting annoying. For precision large areas, I'd like to use a largish ballnose (1/2" for example) to finish mill, then remachine the detail areas where curves are smaller radius with a much smaller tool. Cut3D forces me to re-draw all of those areas anc "overlay" the toolpaths in a manual process.
    I've been looking at various CAM packages for about two months and I'm getting frustrated. I need only to cut 3 axis, and only 3D parts with a remachining function. I've found several that will fit the bill, but all are pushing $3k which is out of the question for me as a hobby user.
    Is there a 3 axis 3D CAM out there for a grand or less that can do a remachining pass with detail tools?
    Here's what I have looked at so far:
    RhinoCAM/Visualmill - requires Pro package ($$$) to do remachining, and the demo RhinoCAM crashes my machine frequently
    BobCAD/CAM - new drawing interface, though I could import my Rhino files. So far I've been less than impressed with the interface but it seems to fit the basic bill. I believe it's closer to $2k than $1k.
    Dolphin CAM 3D - appears to do everything I want but is close to $3k
    Any thoughts on which I should try next? I need to get something in place as I'm doing around 30 hours of cutting / week right now on top of my regular job.
    Feb 2009
    BobCAD will do what you want, and you can get it for $800 - talk them down and don't cave on price until you get what you want.
    Sep 2009
    Looks like it will do what I need. I just got off a demo with them and they can do it by setting up boundaries for the tools.
    Now I just have to work on the price issue.
    Thanks much.
    Monkeywrench Technician DareBee's Avatar
    Jan 2004
    Stratford, Ont. Canada
    VisualMill STD will likely be fine for you.
    I find very little use for the re-roughing.
    I would region off the detail areas where you want a smaller cutter and apply a finish toolpath.
    The re-roughing has to calculate so many variables that it can take ages to generate.
    You could also look at SprutCam Expert (probably $3G ish)
    www.integratedmechanical.ca
  1. Build Thread- machine control software & cam software
    By grttt3 in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 05-06-2010, 02:49 PM
  2. Just IN- MIE Solutions - Free Quoting Software Trial Software available
    By MIE Solutions in forum Product and Manufacturer Announcements
    Last Post: 01-07-2009, 11:42 AM
  3. Software
    By turbotoys in forum DIY CNC Router Table Machines
    Last Post: 08-14-2007, 09:12 AM
  4. First post in the software dept. Free cnc software?
    By runinbymdnt in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 02-06-2007, 10:49 PM
