Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 07-05-2005, 03:58 PM
Net-Man is on a distinguished road
i have a four question for G-code
Hi all.
Iam a New User In This Nice Forum , and i have a Four question ?
1. when i save my file in autocad 2000i to DXF File i say a 3 type of files (AutoCAD 2000 DXF) , (AutoCAD R14/LT98/LT97 DXF) , (AutoCAD R13/LT95 DXF)
and (AutoCAD R12/LT DXF) what is The deffernt Between This Files .
2. How can i convert a DXF file to Gcode and convert Gcode To DXF by form accurate !!!! .
3.how can i read a (Gcode or DXF file ) for convert to (X , Y , Z) File for send to my CNC Machine
4.I want a program (Cad/Cam) to draw a 3D form and convert to Gcode directly.
thanks all.
Old 07-05-2005, 06:21 PM
keithorr is on a distinguished road
My opinion on question #1.
Whenever I need dxf files from a client, I always ask for a file save in R12. It's a basic dxf format, without any autocad dependent features.
Not all cad programs can open the newer AutoCad formats. The R12 is more generic in nature.
Old 07-06-2005, 05:49 AM
Kookaburra's Avatar
Moderator
Kookaburra is on a distinguished road
If you want to convert g-code to dxf, you need a software package that will allow you to do that. The only "cost effective" programs that will allow you to do that (that I know of) is bobcad, vector XT and DeskCNC, mind you I said "Cost Effective". There are others that will do it but the price is too high IMO. I am not aware of any freeware packages that will convert g-code to dxf. There are however shareware packages that will convert DXF to g-code and they work well and I recommend supporting these guys, they produce very basic g-code I know, but to those out there who are doing simple stuff, it may be all you need. If you want an all in one that will convert your g-code to dxf or take your 3-d or 2-D designs and allow you to toolpath them to obtain your desired g-code output, then you will need a cad-cam package seperate to autocad. If that is the way you want to go, then it would be my advice to post your questions on the various packages available to the CNC Zone forums to help you choose the right one. All of them are good in their own way but you will need to decide what you want to do with your software and how much you are willing to spend.
"A Helicopter Hovers Above The Ground, Kind Of Like A Brick Doesn't"
Greetings From Down Under
Dave Drain
Akela Australia Pty. Ltd.
Wierd NC Code and G-Code Tazzer General CAM Discussion 10 01-09-2012 01:07 PM
looking for g code 3d from bobcadcam or simmilar for indexer lpt v5 with g code soft troyswood Ability Systems - LPT Indexer and G-Code 2 12-24-2006 09:21 PM
M code question- Whats the difference? CNCRob G-Code Programing 8 05-20-2005 03:25 PM
G Code to DXF sanders50 G-Code Programing 2 02-16-2005 03:09 PM
Ace Converter G-code Question ljoe1969 Yeager Automation 3 01-22-2004 11:18 AM
