Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 07-07-2003, 05:28 PM
kong is on a distinguished road
Relief models needed
Does anyone know if there is a website that sells 3d models of wood carvings or reliefs? I'm not too hot with 3d cad and so I'd like to cheat!
Old 07-07-2003, 05:32 PM
HuFlungDung's Avatar
Moderator
Just itchin' to carve, are you Kong?
Any kind of preference and size in mind? Do you want to do full 3 axis 3d or 2.5axis?
Old 07-07-2003, 05:37 PM
Never done it before, I just downloaded visualmill free, so something nice and small to start! My machine should be able to cope with 3d, albeit very slowly, 'till I get those motors sorted!
Old 07-07-2003, 08:07 PM
cbcnc is on a distinguished road
Hi Kong,
Try this site for a 3d Jesus:
http://home.alltel.net/mmharper/
He makes some interesting things too.
Chris
Old 07-08-2003, 11:01 PM
robgrz is on a distinguished road
I'll add a plug for my software, MeshCAM. It can import both STL and Bitmap images and generate a toolpath from them. It has a couple of roughing options that, I don't think, FreeMill has. It's currently a free, unrestricted beta. You can download it from http://www.robgrz.com . I'd love to hear some feedback if you have a chance to try it.
Robert
Old 07-09-2003, 04:17 AM
Thanks guys, but no joy so far, I would like a rosette, or something like you would find on a cabinet. I've been hunting the bigger 3d sites, but can't find anything!
Old 07-09-2003, 04:29 AM
Kookaburra's Avatar
Moderator
Kookaburra is on a distinguished road
Kong,
Is a rosette a femail rose? Just joking!!
In your hunts for what you want, if you come across a greyscale image of something that resembles what you want I may be able to help you convert it to a wire frame model or a least a geometrical toolpath.
Good Luck Champ!!
"A Helicopter Hovers Above The Ground, Kind Of Like A Brick Doesn't"
Greetings From Down Under
Dave Drain
Akela Australia Pty. Ltd.
Old 07-09-2003, 06:49 AM
Success, here's a good site for anyone else wanting some 3d reliefs. It's 3d clipart. but there some good programs to convert this to g-code. http://www.3dclipart.net/3d_clipart.htm
Old 09-19-2007, 01:17 PM
yohudi is on a distinguished road
I can do this Easily and for FREE
no problems with this...
see the link below
Direct bitmap to model conversion method
What one man can do another man can do..
BitMaps to Models, tutorials and FREE CNC Software http://cnc4free.org
Old 09-20-2007, 07:40 AM
jfc11 is on a distinguished road
CBCNC,
I cant get that link to work....Can you check to see if it is the correct one
thanks,
Jim
  #11   Ban this user!
Old 09-20-2007, 11:40 AM
grahamshere is on a distinguished road
dont know if you tried this one http://www.vectorart3d.com/ but think they have the best models to carve . Graham
  #12   Ban this user!
Old 09-21-2007, 11:16 PM
Originally Posted by jfc11 View Post
CBCNC,
thanks,
Jim
Yep.. it's the right link... and works fine for me...
here it is again
or just search for "Direct bitmap to model conversion" in the general prog and design section of the forum.
hope this helps...
STL Relief models HomeCNC DIY-CNC Router Table Machines 7 12-03-2011 04:47 AM
Info needed for these servos Splint General Electronics Discussion 27 11-10-2008 04:24 AM
CNC mini-lathe conversion help needed. minilatheman Mini Lathe 5 05-24-2005 08:47 AM
What's needed for complete setup? LeeWay Gecko Drives 1 03-09-2005 09:38 AM
cad models for common parts. fyffe555 General CAM Discussion 7 11-18-2004 01:40 AM
