Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 06-20-2005, 02:57 PM
itsme's Avatar
itsme is on a distinguished road
EdgeCAM 9.5
Hi there,
Does anyone know anything about Edgecam 9.5?
What sort of capabilities does this software have? Would it be able to do 4 axis milling (continuous or indexing 4th axis), or is it one of those programs that needs extra bits added on to get those capabilities?
Anyone with any experience with this software?
Warren
Have a nice day...
Old 06-21-2005, 08:18 AM
itsme's Avatar
Surely someone knows something??? Any help would be appreciated.
Have a nice day...
Old 06-21-2005, 10:33 AM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
It is a program that I may be considering in the future due to its integration with SolidWorks but in general a lot of the guys here are DIY home shops and don't usually use such pricey software.
I was hoping you got more response as well so I could have some more info.
Cheers
www.integratedmechanical.ca
Old 06-22-2005, 03:42 AM
MIKE JEFFERS is on a distinguished road
hello
going on training for edgecam soon have used it a bit in demo mode (tutorials etc)
its solidworks intergration being key to our operation, it however (initally) seems cumbersome ,compared to others iv'e used ,so we'll see what transpires.
Old 06-24-2005, 10:12 AM
ty1295 is on a distinguished road
I have been using edgecam for 5+ years now.
Unfortunetly I don't get to do any fancy milling, or anything so I have not learned how. I am 99% sure it can do it and do it well.
I actually really like edgecam. I have not got the solids to machine correctly but it is within my knowledge on how, not necc. the software.
Old 06-24-2005, 02:36 PM
wisp's Avatar
wisp is on a distinguished road
I use edgecam on a daily basis, and yes it is great for doing 4 axis machining, and 5 axis positional machining, ie, not the greatest at simultaneous 5 axis. I use it to machine solid models with little problems. We have 8 programmers where i work, and all of them used some other cam system before they started using edgecam, and all of them say edgecam is much easier once you learn to use it, especialy compared to mastercam and 4 axis programming. It is also MUCH easier to configure your own post processor with edgecams code wizard. I can honestly say that we NEVER make hand edits to our programs, and we have over 40 different posts, everything from old ass Lodge & Shipply's to brand new Haas mills.
I demo'd OneCNC a few weeks ago, and I can say there is no comparison. Its like comparing a Mustang to a Ferrari, Mustang's rock, but they are no Ferrari. The one bad side, and I mean BAD side to EdgeCam is the price. See the pricing below.......
EN302-0 EdgeCAM Entry Turning $ 3,000.00
2D and 3D Design. 2 Axis Turning. Code Wizard, Text Editor, ToolStore, Job Reports, Toolkit Assistant, Technology Assistant, Job Manager, RS232 Communications, Simulator Lite and Utilities. IGES, DXF and DWG loaders.
ENEE0-0 EdgeCAM Entry Milling $ 3,000.00
2D Design. 2.5 Axis Milling. Code Wizard, Text Editor, ToolStore, Job Reports, Toolkit Assistant, Technology Assistant, Job Manager, RS232 Communications, Simulator Lite and Utilities. IGES, DXF and DWG loaders.
EN330-0 EdgeCAM Milling $ 6,000.00
2D and 3D Design. 3 Axis Milling. Code Wizard, Text Editor, ToolStore, Job Reports, Toolkit Assistant, Technology Assistant, Job Manager, RS232 Communications, Simulator Level 1 and Utilities. IGES, DXF and DWG loaders. Allows for simple indexing or datum shifting using M codes within a single plane i.e. not tombstone.
EN20C-0 EdgeCAM Turning $ 7,000.00
2D, 3D and Rotary Design. 2,C and Y Axis Turning. Code Wizard, Text Editor, ToolStore, Job Reports, Toolkit Assistant, Technology Assistant, Job Manager, RS232 Communications, Simulator Level 1 and Utilities. IGES, DXF and DWG loaders.
EN3M0-0 EdgeCAM Advanced Milling $ 7,000.00
2D, 3D and Rotary Design. 3 Axis, Multiplane and Rotary Milling. Code Wizard, Text Editor, ToolStore, Job Reports, Toolkit Assistant, Technology Assistant, Job Manager, RS232 Communications, Simulator Level 1 and Utilities. IGES, DXF and DWG loaders. Multiplane and Rotary Milling provides machining around a rotary axis including 5-Axis positioning (table mounted rotary axis only).
EN4BC-X EdgeCAM Advanced Turning $ 10,750.00
2D, 3D and Rotary Design. 2 Axis, 4 Axis and C & Y Axis Turning, B Axis Mill/Turn with support for a sub-spindle. Code Wizard, Text Editor, ToolStore, Job Reports, Toolkit Assistant, Technology Assistant, Job Manager, RS232 Communications, Simulator Level 1 and Utilities. IGES, DXF and DWG loaders.
Production
ENEEE-0 EdgeCAM Entry Production $ 5,000.00
A bundle of Entry Turning and Entry Milling
EN0PP-0 EdgeCAM Production $ 8,000.00
A bundle of Milling and Entry Turning
EN0PP-P EdgeCAM Advanced Production $ 11,500.00
A bundle of Turning and Advanced Milling
www.cncfusion.com CNC kits for Sieg mills and lathes
Old 07-07-2005, 07:11 AM
theov is on a distinguished road
Originally Posted by itsme
Hi there,
Warren
Yes this can do both, you can have a post written to index or to have full 4th axis.
Whish I could have the fortune to work on EdgeCam again. Working on CamWork at the moment. Well it doesn't works if you compare it to Edge. Worked on Edge for 5 years.
Radius Cutter in EdgeCAM? Inventor General CAM Discussion 3 01-06-2005 02:05 PM
Edgecam with Autocad dwg for Lathe wjbzone General CAM Discussion 4 01-05-2005 11:54 AM
EdgeCAM for Wire Klox General CAM Discussion 2 02-18-2004 07:26 PM
EdgeCAM info and helpful use?? CNCLaser General CAM Discussion 1 09-18-2003 02:52 PM
Any one using Edgecam? mossy General CAM Discussion 4 07-24-2003 03:00 PM
