| General CAM Discussion Discuss CAD/CAM software and Design software methods here! |
My software is not getting the job done, or I’m not going about it the right way. I’m new to the world of CNC I recently purchased a small CNC router that runs a trim router as a spindle. My purpose is very single minded the only thing I wish to accomplish is making inlays in wood, these inlays for example are walnut inlayed in maple and they are at lest 1” thick. The problem I’m encountering is I can’t seem to get a good fit the software I’m using to create the vector / plotter file is Corel 12. The G code seems to jerk or leave flat spots. The way I try to make the file is create a ¼ wide line Trace it on outline thus creating two parallel lines which I separate to create two files. Seems like is should work, but its just not coming out clean. I can’t determine if its my plotter file or the G code that’s causing the problem. Now is this a good way of pursuing this problem or dose somebody know of a better way of creating inlay patterns. |
| Can you post a sample file? Some of us can maybe backplot it and see how it looks in a real cadcam program. Are you getting gouges? Does the tool lift when it needs to? Are all the movements lines, no arcs?
It goes from one point to the next in a strait line and in a curve I end up with a small flat maybe .005”. The other pattern will have the save flats thus not lining up, and I do have it set at 0. I’m thinking if there is software that will generate the code to the right of left of the line not the center it would probably solve my dilemma. |
| Gcode please
| Well, I backplotted the gcode (using OneCNC), and I would say it looks okay. I'd cut it ![]() If you are having machine jerk problems, it may be due to lack of processing power in your cnc, attempting to run very short segment code at high speed. Turn down the decimal place accuracy on your posting program, you don't need 6 significant digits This alone may improve processing speed on your cnc.Then, after reposting at 3 or 4 digit accuracy, then if you still see the machine jerking, then reduce the feedrate (maybe in half) and see if the machine can process it fast enough to keep the drive buffer full.
| Btw, if you can figure out how to do G41/G42 tool radius comp on your machine, then you can perhaps make do with one centralized profile and cut on either side of it. But, there could be a problem with entry/exit to/from the profile. I'd recommend for that type of work that you might take a demo of OneCNC Express. This will allow you to pocket the interior, as well as profile offset either side of a line, choose different tools on a mere whim, etc. It'll put the fun into your work
#11
| You're right, Dave. Several lines of "look ahead" are required of the controller. It needs to keep the command buffer to the motors full, so that continuous motion is possible. G41/G42 could certainly be used on a centralized toolpath for your purpose. However, applying tool comp requires a bit of practice, to see exactly how the machine begins and ends when it starts onto the profile, and leaves it. This is because the machine begins at some start position, tool comp is called, and it then has to get into position to the right or left of the profile. The amount of the movement will be the tool's radius. This is called the "lead in" to the radius compensated path. You'll have to insert the tool's diameter (or radius, depending on how the controller is set up) in its tool comp register. Then, you have to call for the comp to be applied, typically with a G41 D1 for tool #1 When the path is completed, the compensation should be cancelled with a G40 in the code.
| Engraving Software | The Wizard | General CAM Discussion | 31 | 03-29-2005 05:38 AM |
| What CAD/CAM software are you using? | marting | General CNC (Mill and Lathe) Control Software (NC) | 11 | 01-29-2005 04:54 PM |
| Software sales or "license transfers" | metlmunchr | BobCad-Cam | 3 | 07-05-2004 04:47 PM |
| ***One stop CNC software guide*** | ynneb | DIY-CNC Router Table Machines | 4 | 05-27-2004 04:31 PM |
