Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 07-01-2003, 12:59 AM
WOODKNACK's Avatar
WOODKNACK is on a distinguished road
Tool Change
What is the code for a tool change. I am doing a pc board and after I do my trace lines I want the machine to come up and I add the drill bit and hit a key and have it goto drilling the holes. Any ideas on this?
My little piece of the web!
http://users.adelphia.net/~wjdupont
Old 07-01-2003, 05:52 AM
E-Stop is on a distinguished road
Typically Txx M6 will make an automatic tool change. But it sounds like you want to manually make a tool change and then "hit a key" to go again. If that's the case an M6 without any tool number should take the "Z" axis home and orient & stop the spindle. The line after the M6 should be M0 to halt the machine until "start" is pushed again.
Old 07-01-2003, 09:44 AM
WOODKNACK's Avatar
Have no home switches yet?
Well I have no home switches yet! Can I just make the Z come up and use like m0 to stop the program, do my tool change and then start it again?
I am using Ace Converter to convert the gcode. There is a place where I can set Pre-Priority codes for each layer! So I was thinking I could just setup the code to make the z come up and stop the program and then start it again.
Would this work???
Old 07-01-2003, 09:47 AM
CNCadmin's Avatar
Site Owner
CNCadmin has disabled reputation
Why are you using ace converter?
Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 07-01-2003, 11:20 AM
Woodknack--
I don't see why that wouldn't work. The idea is to get the "Z" axis up enough for clearance and then stop and wait for you to do something. The M0 will cause the machine to stop regardless of where the machine is positioned. Then when you press start again, it should start running right where you left off.
Old 07-01-2003, 12:54 PM
WOODKNACK's Avatar
Ace converter
CNCADMIN,
You ask why I am using Ace? What else should I use? THe layout for the board I have is in a DXF format! I got the DXF from a friend that somehow put it in cad. So I really dont have any other option do I??
I have been using turboCad and Ace Converter and the 2 have worked like a charm so far! Seems to be alot you can do with Ace Converter too! Im always learning something new.
ESTOP,
Thanks for the help I'll try that out. So m0 just stops the program and waits for you to start it again? Is there any number after M0 that I should use?
Old 07-01-2003, 01:23 PM
HuFlungDung's Avatar
Moderator
Yes, a solitary M0 should be good for "program hold" for eternity
If you are thinking of a timed dwell, that would usually be a G04 plus a number in, perhaps, milliseconds of dwell. You would only use this for your purposes if you're playing "Russian tool change" with your cnc buddies.
Old 07-01-2003, 01:35 PM
WOODKNACK's Avatar
HuFlungDung,
Too Funny!!! LOL I will keep that in mind next time I have someone over I don't like too much!!! HEHEHEHE.
I can see it now, HURRY, HURRY AAAAHHHHH TOO LATE!!!! LOL
I guess I'll have to make that a longer millisecond next time!!! LOL
Old 07-12-2003, 09:44 PM
Kookaburra's Avatar
Moderator
Kookaburra is on a distinguished road
What software are you using to drive the machine? The new DeskCNC has gerber and exelon tool pathing and drilling built in so you don't evern need to convert it to a dxf in the first place, just get the track and apeture file *.pcb straight ouf of your pcb development software eg:Protel and go for it, the cam wizard in DeskCNC lets you put in the tool dia for contour offset, great stuff, it also has a background tool change function so if you command T1 M06 it reads a file called toolchange.cfg and executes the lines of code the user puts, every one above has said all of the right stuff, it is just that you ony need to put it once and then it is stored until you change it, you can even write in functions for doing an automatic tool change later on down the track. Wait and watch DeskCNC, big things happening there.
"A Helicopter Hovers Above The Ground, Kind Of Like A Brick Doesn't"
Greetings From Down Under
Dave Drain
Akela Australia Pty. Ltd.
Old 07-12-2003, 09:53 PM
CNCadmin's Avatar
Site Owner
Re: Ace converter
Originally posted by WOODKNACK
CNCADMIN,
Try this if you have Auto cad or use Deskam
http://cnczone.com/showthread.php?s=&threadid=1168
Thank You,
Paul G
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
  #11   Ban this user!
Old 07-12-2003, 10:26 PM
boxwood is on a distinguished road
Woodknack
M0, Should handle the program stop to allow you to physically change the tool, but remember ypu need to set the tool lenght offset also for the new tool and also call that tool # after the change. like this Tx. or set tool to z zero after the change and no tool number is required
Ray
Learn from the mistakes of others you can't afford to make them all yourself!
Tool length sensing! Swede FlashCut CNC 15 10-12-2005 08:51 PM
tool change Dwallace General CNC (Mill and Lathe) Control Software (NC) 1 03-24-2005 01:17 PM
Quick change tool system (milling) mark c General Metal Working Machines 3 02-17-2005 07:50 AM
Tool Changer Problems Snel Haas Mills 5 08-11-2004 09:56 AM
fanuc tool change prompt light cam Machine Problems, Solutions , Wireless DNC, serial port 0 04-02-2004 09:27 AM
