Results 1 to 6 of 6
Thread: Problems with Lantek 27 / SQL Server
    Feb 2009
    brazil
    Please... somebody help me....
    I installed Lantek Expert CAM v27 a thousands times... i tried to do it in 4 computers, but i always receive the same answer... I canīt do a database... the software just donīt recognize the SQL Server... It says that the server doesnīt exist or it says that the SQL server cannot validate the service accounts. What can i do??? iīm usin winXP SP 2......
    Iīve posted some images... it can explain better..... Sorry for my english... Thanks guys
    http://img709.imageshack.us/i/capturarrj.png/
    http://img576.imageshack.us/i/capturar2.png/
    Registered WayneHill's Avatar
    Mar 2004
    Michigan
    You must have run out of licenses after 1000 installs.
    Wayne Hill
    Feb 2009
    brazil
    Iīve tried only with one hardlock license... and i tried to many times.. without succes... the liscense is ok... iīm having problems with the sql server.
    Mar 2004
    Michigan
    Is it SQL 2005 express? Have you downloaded the SQL management studio from Microsoft? You can change the SQL administrator password with it. Also check if the SQL agent is running after restart. Update microsoft WinXP to SP3 and install the latest Framework update. That will keep you busy for two hours...
    Wayne Hill
    Feb 2009
    brazil
    Itīs SQL 2005 express... iīve tried seting another password, and updated windows, but it doesnīt work... iīve activated the sa login to it... with the password cib1234, but it doesnīt work too..
    Registered RAVENEXTREME's Avatar
    Apr 2010
    Portugal
    Smile The Computer ????
    Hello to all
    Hi zei_narukami,
    Did you have first installed it at another PC before that ?? Do you have the LANTEK EXPERT cd with you ? Can you run the setup correctly ? Ativirus running ? Firewall ? Cleanned REGEDIT keys from Lantek ? Windows directory without Lantek folder ?
    Check all my questions if you still dont have the solution
    Take care and if you need say something
    1. Server Issues (4-6-08)
      By CNCadmin in forum CNCzone Site News and Contests
      Last Post: 04-07-2008, 10:49 AM
    2. Dnc server
      By PSIman in forum Machine Problems, Solutions , Wireless DNC, serial port
      Last Post: 07-18-2006, 09:51 AM
    3. It's an ad server
      By doug6949 in forum Alibre Design
      Last Post: 07-25-2005, 12:38 PM
    4. RPC Server?
      By BIGFERB in forum Mach Software (ArtSoft software)
      Last Post: 09-02-2004, 09:41 AM
