Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 05-08-2010, 06:18 AM
Atomic_Sheep is on a distinguished road
Why CAD?
Yes this is a CAM section, but I was just wondering, if you are going to CNC something... why not go straight for CAM?
Old 05-08-2010, 08:39 AM
Gold Member
Caprirs is on a distinguished road
You have kinda answered your own question. "If you are going to CNC something", then you are correct. However, what do you do when the part you draw has to be contracted out because it is not within your capabilities? Or when you need to generate a print with all dimensions and tolerances, plating specs, material callouts, surface finish requirements, welding, thread inserts, etc.? In shops where one person programs and someone else machines, the guy on the floor needs a print to work with showing all the features he needs to inspect.
The CAD systems focus on not just the drawing aspect, but also the ability to communicate detailed information to others. Typcially, CAM systems are not efficient at creating a print.
Old 05-08-2010, 08:46 AM
ger21's Avatar
If you can start in a CAM program, then your CAM program has CAD functionality built in. You need a drawing or model before you can create toolpaths. That drawing or model needs to be created with CAD. There's really no way around it.
Old 05-08-2010, 09:41 AM
Ah I see... once again, I've overcomplicated simplicity.
And that made it crystal clear... thanks
