Results 1 to 2 of 2
Thread: CAMSHAFT MILLING USING 4 AXIS MACHINE
    May 2010
    UNITED KINGDOM
    Hello and welcome to my 1st post !
    I'm building a small desktop milling machine and ultimately want to use it for ( amongst other things ), milling camshafts for model petrol engines.
    Is there a dedicated set of software for canshaft milling or alternatively what software should I be using ( preferably free or fairly cheap ) to generate the code for this ?
    I'll be using Mach 3 to drive the mill, and it will have a fourth axis ( dividing head or rotary table ), and also anticipate using Meshcam for 3D stuff.
    I can generate DXF file of the shafts via my CAD programme easily ( Design Cad v13 ), and I guess would use this to feed into any code generating software ( or am I wrong ? ).
    Any help much appreciated.
    Nick.
    Moderator HuFlungDung's Avatar
    Mar 2003
    Use the advanced search on this site to search for posts by NC Cams.
    He had lots to say about that particular topic, and you aren't going to like it Unfortunately, he is no longer with us.
  1. DIY 3 axis CNC Milling Machine.
    By Eagle23 in forum General Metal Working Machines
    Last Post: 10-19-2009, 09:20 PM
  2. Advantage of a 3 axis CNC Milling machine
    By george_kj in forum General Metal Working Machines
    Last Post: 04-28-2008, 05:46 AM
  3. How many axis to DRO on a Milling machine?
    By hotponyshoes in forum General Metal Working Machines
    Last Post: 05-15-2007, 03:16 AM
  4. 5 axis milling machine
    By toneV8 in forum General Metal Working Machines
    Last Post: 11-29-2005, 05:11 AM
  5. Replies: 3
    Last Post: 05-18-2005, 12:15 PM
