2" square if you use an offset for your tool...
What size square should this gcode cut??????
G00 X0 Y0
G00 X-1.0 Y-1.0
G01 Z-.1 F8
G01 X1.0 Y-1.0 F8
G01 X1.0 Y1.0 F8
G01 X-1.0 Y1.0 F8
G01 X-1.0 Y-1.0 F8
G00 Z1
My little piece of the web!
http://users.adelphia.net/~wjdupont
Thats funny. My machine is cutting 1 inch square.
Are you using a 1/2" tool?
Now Im wondering about my machine setup??
I am using 1/2-20 threaded rod and am microstepping at 1/8.
My stepper are 400 or .09 deg.
maybe I dont have that setup right?
actually I have a 1/16 end mill bit in it!
If I were to cut that with a 1/2" tool, in the direction you're going I'd need a G42 in the beginning, otherwise I'd get a 1" square.
Ya i can see that if you are using a 1/2 tool but I am only using a 1/6 or .0625 end mill but. something is not setup right.
I'm at a loss...I've had that sort of thing happen, but it was simply due to offsets being entered wrong.
I figured it out!!! I had my axes setup with the wrong numer.
it was set up for a 200 stepper motor not a 400.
was set for 0.00003125
changed it to 0.00001562
I am NOW getting a 2 inch square!
Glad to hear it!![]()
Hope you mean NOWI am not getting a 2 inch square!![]()
Wee aim to please ... You aim to ... PLEASE.
