| General CAM Discussion Discuss CAD/CAM software and Design software methods here! |
Hello, I'm quite new to CNC and milling and started using Freemill to machine simple 3d objects. It works ok for single sided objects, but I need to mill a cone and would like to turn the part around and mill the other side. Problem is that I cannot figure out how to rotate the part so that the Y-axis lines up. I set the parting plane into the middle of the object created a post-proc.file for the first side, then went back to the milling axis page rotated the part 180 degrees and created the second post-proc. file Problem is that I don't know which dimensions Freemill uses as the raw part size? It is bigger than the part itself for sure, even if the offsets are 0. When I turn the part around, I have had an offset of 12 mm. I'm milling with a 8mm mill and set an y-offset of 3.9 (as my raw block was 3.9 mm larger than the part. Is this a coincidence that I get 8+3.9 ^= 12?? How should I chose my part zero on my machine? do I have to compensate with the y-offset? How do I enter the raw block size into Freemill? Also, the Mecsoft page claims that you can use ball or flat or corner radius mills, but I cannot set the radius to 0, it is limited to half the diameter?? Any help greatly appreciated... |
| I'm assuming the cones final height dimension is too tall for your Z axis and this is why you are machining the part on its side? Because if not I would definitely machine it standing up if not.
__________________ Theres a good side to every bad side, you just have to look around the corner. |
Indeed, it is too long. I have not retried since, haven't found the time, but I'd still be interested in any experience with free-mill |
| Tags |
| freemill 2-sided |
| FreeMill | CNCadmin | Visual Mill | 21 | 07-28-2011 02:11 PM |
| 2 Sided milling | dirtdiggler | Rhinocam | 2 | 10-06-2009 11:33 PM |
| Two Sided Milling Fixture | Mihelich | Work Fixtures and Hold-Down Solutions | 2 | 08-20-2009 02:50 PM |
| Milling a singled-sided SMD circuit | Jay C | PCB milling | 8 | 01-05-2009 02:43 PM |
| Can MeshCAM do 4 or more sided milling? | digits | GRZ Software- MeshCAM | 5 | 04-03-2008 05:14 PM |
