| General CAM Discussion Discuss CAD/CAM software and Design software methods here! |
| What X & Y dimensions can your Mill handle? I have a selection of GCode files that range from the Harley Davidson "Bar & Shield" Logo through to nature scenes for Art Plaques...
__________________ Frank www.theworkshop.ca |
| That's more than enough to handle any cut-files I have... If I can get these attached here's the HD Logo as a DXF so you can scale it to what ever size you want... I had it as 3 seperate DXF files that can be imported into 1 drawing... The DXF's originally came out of Corel Draw so I hope that the export is compatible with your soft ware... If you want the actual GCode let me know...
| Frank I imported your HD3 file into Mach2 and it looked fine, I then generated the GCode, but I only get the bottom of the shield, as a newbie to all this stuff what am I doing wrong? Any chance of posting the files as GCode? Steve |
| Are you using the demo of Mach2, which is limited to only 1000 lines of code?
#10
| It's Turkey Season up here and I just got in from the bush... I'll attach the GCode to this message... News Flash!!! I screwed-up the original attachment(s)... The zip file has both DXF & GCode for an engraved Shield & an Embossed version... the Files are organized in a odd fashion but for a good reason... HD1.xxx is a rectangular 4-point file that shows the outer most limits that the Maching will take place within... HD2.xxx is a section of code that probaly is the top half, while... HD3.xxx is the lower or remaining potion... this logo/job was done while I was working out bugs with my first mill, and splitting the DXF & Gcode was for debugging... If you can import all the DXF's in Whatever you can make one Cut file and scale to an appropriate size... Sorry for the confusion... But the Zip file is your best bet...
| Finding The Right Router | Crushmonkey | Commercial CNC Wood Routers | 22 | 06-19-2006 01:17 AM |
| Quick built router | CNC Darren | DIY-CNC Router Table Machines | 10 | 06-05-2005 08:09 PM |
| long term stability of wood framed router | dave925 | DIY-CNC Router Table Machines | 17 | 05-05-2005 11:33 PM |
| my new longbed router | cncspear | DIY-CNC Router Table Machines | 16 | 10-15-2004 08:36 PM |
| buscht's cnc router | buscht | DIY-CNC Router Table Machines | 25 | 04-13-2004 11:43 AM |
