Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 04-26-2005, 11:57 AM
Paul in OK is on a distinguished road
Software choices
I see there are several choices for software. What would be the best 'package' to choose for setting up a router with. (Still looking at the k2cnc machines). I have thought about Rhino/visual mill package and Mach II. Are all three neccassary? I currently use AutoCad and an old EZcam for stuuf where I work. But am putting together a package for a potential customer.
Thanks for the help.
Old 04-26-2005, 12:34 PM
ger21's Avatar
You need Mach2/3 (or something similar) to actually control the machine. Then you may need a CAD and or CAM package to create the gcode that the machine controller will use. What software you choose may have sokmething to do with what you want to make with your router. There are a lot of woodworking specific CAM packages, but they are all quite a bit of money.
Old 04-28-2005, 08:11 AM
NWPJOEL is on a distinguished road
What are you going to be using the software for, and how advanced are the users? Also, do they already have something they own? If starting from stratch I would go with Artcam if it is design elements, but for technical, like patters or molds, mastercam is good, and fairly cheap.
Old 04-28-2005, 08:31 AM
ger21's Avatar
"Fairly cheap" is relative. Both ArtCAM and MasterCAM will cost twice as much as a K2CNC router. Not sure what his budget is, though. If he was talking about the full VM5 with Rhino, then that's pretty close to ArtCAM, I guess.
Old 04-28-2005, 08:47 AM
Thanks fo rthe replies. I will be the one using the stuff. I use AutoCad and an older EZCam program at work, so am familiar with drawing and code. Have tried to use Bobcad (we have that at the shop as well), But always go back to AutoCad. Total budget is around $5k, machine and all. Am looking at the k2cnc 2525.
Augh. Too many choices in CNC control software MadMax General CNC (Mill and Lathe) Control Software (NC) 4 07-08-2005 01:00 PM
Engraving Software The Wizard General CAM Discussion 31 03-29-2005 05:38 AM
Software choices? Holy cow! LeeWay General CAM Discussion 6 03-19-2005 07:52 AM
***One stop CNC software guide*** ynneb DIY-CNC Router Table Machines 4 05-27-2004 04:31 PM
