Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 04-24-2005, 06:10 AM
CNCgr is on a distinguished road
Point cloud editing
I'm working on a 3D scanner idea and when it works it will output 3D point clouds of the object I'm scanning.
What CAD program would allow me to manipulate these files (e.g. remove points to smoothen a surface, turn into 3D solid etc)?
Nikolas
Old 04-24-2005, 07:31 AM
DAB_Design is on a distinguished road
www.rhino3d.com
Old 04-24-2005, 07:51 AM
Can Rhino do that without plug-ins? Because I've seen some pointcloud plug-ins for it and other programs.
Thanks, Nikolas
Old 04-24-2005, 08:09 AM
Before I go on, I should say that I have never actually done this (never actually seen a point cloud file). What I have done, is created a text file with just a few points (around 20) and messed around with it. So take this with a grain of salt....
It will open/import point cloud files. From that, you can manipulate the points. Either as a group, or individually. From there, I believe you would have to create curves using the points. Then build your surfaces from the curves you created.
If you have a point cloud file, you could send it to me and I'd be happy to try whatever you think you would need done to it.
Rhino also has an demo download. Unrestricted except it will only save 20 times, if I remember correctly.
Old 04-24-2005, 08:54 AM
Thanks, I don't have a file yet, I'm still working on the software that will create them.
I guess the plug-ins are for automatically creating a surface from the points (some have tool compensation if you digitize with a probe).
When I get to the point that I can create the files I may ask again.
Nikolas
Old 04-24-2005, 11:06 AM
ger21's Avatar
Any CAD or modelling software that allows point editing would work. It might be very tedious, though. And I doubt you'd be able to turn a point cloud into a solid.
Software to manipulate point clouds? ckirchen General CAM Discussion 3 04-04-2005 08:07 PM
Where can I download Point cloud sample data ?? Calico Rhino 3D 0 03-19-2005 09:16 AM
point data in autocad trubleshtr General CAM Discussion 3 03-11-2005 05:32 AM
Point Cloud Conversions Fish General CAM Discussion 3 12-26-2004 08:13 PM
Point Cloud Freddy Digitizing and Laser Digitizing 4 09-23-2004 10:18 PM
