| General CAM Discussion Discuss CAD/CAM software and Design software methods here! |
I have joined 2 gcode programs together, both run seperately okay, I have the pause and tool change in the middle of the gcode T0202 see below The 1st programs runs and takes 2 mill off diameter, it then pauses I change the tool to start click cycle start to continue. but when the tool starts up it goes right through and does not start at bar can someone please look at the gcode for me and see if I have missed something, i am using a connect 121 lathe with mach3 turn S600 G18 G40 G49 G90 G94 G80 M3 G04 P6 G0 X2.005 Z0.3 F20 G0 X1.385 G1 Z-2.99 G0 X1.985 Z-2.7 G0 Z0.3 G0 X1.365 G1 Z-2.99 G0 X1.965 Z-2.7 G0 Z0.3 G0 X1.345 G1 Z-2.99 G0 X1.945 Z-2.7 G0 Z0.3 G0 X1.325 G1 Z-2.99 G0 X1.925 Z-2.7 G0 Z0.3 G0 X1.32 G0 Z0.3 G1 Z-2.99 G1 X2.005 G0 Z0.3 F5 G0 X1.3 G1 Z-3 G1 X2.005 G0 Z0.3 G30 M6 T0202 S600 G18 G40 G49 G90 G94 G80 M3 G04 P3 G00 X1.707 G00 Z-0.69 F5 G00 Z-0.69 G00 X1.707 G01 X1.287 G00 X1.707 G00 Z-0.51 G00 X1.707 G01 X1.287 G00 X1.707 G00 Z-0.69 G00 X1.687 G01 X1.267 G00 X1.687 G00 Z-0.51 G00 X1.687 G01 X1.267 G00 X1.707 G00 Z-0.69 G00 X1.667 G01 X1.247 G00 X1.667 G00 Z-0.51 G00 X1.667 G01 X1.247 G00 X1.707 G00 Z-0.69 G00 X1.647 G01 X1.227 G00 X1.647 G00 Z-0.51 G00 X1.647 G01 X1.227 G00 X1.707 G00 Z-0.69 G00 X1.627 G01 X1.207 G00 X1.627 G00 Z-0.51 G00 X1.627 G01 X1.207 G00 X1.707 G00 Z-0.69 G00 X1.607 G01 X1.187 G00 X1.607 G00 Z-0.51 G00 X1.607 G01 X1.187 G00 X1.707 G00 Z-0.69 G00 X1.587 G01 X1.167 G00 X1.587 G00 Z-0.51 G00 X1.587 G01 X1.167 G00 X1.707 G00 Z-0.69 G00 X1.567 G01 X1.147 G00 X1.567 G00 Z-0.51 G00 X1.567 G01 X1.147 G00 X1.707 G00 Z-0.69 G00 X1.547 G01 X1.127 G00 X1.547 G00 Z-0.51 G00 X1.547 G01 X1.127 G00 X1.707 G00 Z-0.69 G00 X1.527 G01 X1.107 G00 X1.527 G00 Z-0.51 G00 X1.527 G01 X1.107 G00 X1.707 G00 Z-0.69 G00 X1.507 G01 X1.087 G00 X1.507 G00 Z-0.51 G00 X1.507 G01 X1.087 G00 X1.707 G00 Z-0.69 G00 X1.487 G01 X1.077 G00 X1.487 G00 Z-0.51 G00 X1.487 G01 X1.077 G00 X1.707 F5 G00 Z-0.5 G01 X1.057 G01 Z-0.7 G01 X1.707 G30 M5 thanks in advance scotty |
| Hi, Not experienced on lathes. Are you saying that tool 2 is moving to the wrong position? "...right through and does not start at the bar..." If so, I notice that you have G40 and G49 after the T0202 - don't those codes cancel cutter compensation (as they do on a mill)? This would put your tool in the wrong position. (Tool 1 may be working correctly, if you have left its offsets as zero and set your origin using Tool 1 as a reference tool.) DP |
| Newbie Q: (Mach/Gcode/Tormach?) display vars? | rc33 | Tormach PCNC | 10 | 11-18-2008 03:16 PM |
| Help with gcode | sunlight | Mach Mill | 5 | 11-12-2007 06:49 PM |
| I have a problem with my gcode or my conversion to gcode , everything is tiny? | NickLatech | G-Code Programing | 0 | 03-10-2005 12:46 PM |
| GCode | rogerbureau | Carken Products (Deskam, DeskCNC etc) | 1 | 02-07-2005 07:36 AM |
| gcode to gcode converter | july_favre | General CAM Discussion | 4 | 05-24-2004 06:51 PM |
