| General CAM Discussion Discuss CAD/CAM software and Design software methods here! |
| Hello ! I need simulate cutter compensation with G41/G42 with vericut 7.0 In Vericut 6 is like this: (first put the value in the tool manager, add cutter comp) project=> processing options=> g-code=> settings, and set the "process cutter comp" dropdown to on-default to zero. But in Vericut 7.0 .....................??????? Thanks. |
| Hi meegers! Easy....................... Tool manager In a tool to add cutter compesations, right button, "Add cutter compesation" apears: Ø1......................this is for diferents correctors to be activate with "D" (one tool can take more than one corrector) and in the right column input the radio of the tool. Best regards. |
Hi, you have 2 methods - the old one with the table - the new one with the tool manager and in the both cases, you need to setup the properties of your "setup". click on "setup", go to the bottom ( ), G-code tab and them select the option that you need for the 'process cutter comp' .bye |
| Hello, In the V7, the method is the same than V6. In V7, you need to click on the setup line in the project three. The menu appear on the bottom. After, like V6, you have G-code setting and process cutter-comp option. If you select "on-default to zero", you need to define a radius compensation in the tool manager. If you select "on-default to full radius", VERICUT read take the radius of the tool for the compensation. Small problem : the sketcher tool : VERICUT takes the biggest one. After, the other possibility, if you use a new V7 controller, is the "ProcessCutterComp" macro that you can find in the event of your controller. In V7, it's directly "g-codes processing" windows ( icon G1). Bye |
| Build Thread- Vericut 6.0 Cutter Comp | Boomer | General CAM Discussion | 2 | 01-20-2010 12:10 PM |
| Need Help!- Vericut and cutter comp | chestervomkorte | General CAM Discussion | 0 | 09-07-2009 03:10 PM |
| Need Help With Cutter Comp | Pmp Audio | Fanuc | 7 | 07-02-2009 02:43 AM |
| Cutter comp on an id hole< cutter diam.?? | PaintItBlue | Haas Mills | 5 | 05-05-2008 06:30 PM |
| 18-it cutter comp | newcinhypro | Fanuc | 1 | 01-25-2006 08:00 PM |
